| Literati914 |
Jan 13 2026, 01:08 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,185 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Couple days ago I picked up two new Odyssey PC925 batteries from a marketplace seller who was supposedly selling them for his dad. The story was that his dad bought them for a couple of electric bike builds and they were too heavy. Dad chose something else after only opening and trying one of them (one was unboxed and one had never been opened when I purchased). So they sat for 4-5 months, his dad said 'get whatever you can for them'. The seller had them at $200 a piece, before dropping them to $100 each - which is what I bought them for.
The one that was already opened was only showing like 7V so I put it on a little charger I already had (not necessarily the recommended type, that I'll need to purchase I guess). I kept a watch on it so it did not over charge.. but I finally took it off the charger when it reached 12.25V or so (took a long time tbh). I installed it in a 2.5L Volvo wagon (will be going in 914s eventually), it showed 14.3-4v, so I did a 20+ mile loop on the freeway to finish topping it off. I did not check it as soon as I returned but about and hour after the drive, it's still only showing like 12.15V. Is this just a bad battery or need more (proper) charging? |
| Artfrombama |
Jan 13 2026, 01:27 PM
Artfrombama ![]() ![]() Group: Members Posts: 417 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States
Couple days ago I picked up two new Odyssey PC925 batteries from a marketplace seller who was supposedly selling them for his dad. The story was that his dad bought them for a couple of electric bike builds and they were too heavy. Dad chose something else after only opening and trying one of them (one was unboxed and one had never been opened when I purchased). So they sat for 4-5 months, his dad said 'get whatever you can for them'. The seller had them at $200 a piece, before dropping them to $100 each - which is what I bought them for. The one that was already opened was only showing like 7V so I put it on a little charger I already had (not necessarily the recommended type, that I'll need to purchase I guess). I kept a watch on it so it did not over charge.. but I finally took it off the charger when it reached 12.25V or so (took a long time tbh). I installed it in a 2.5L Volvo wagon (will be going in 914s eventually), it showed 14.3-4v, so I did a 20+ mile loop on the freeway to finish topping it off. I did not check it as soon as I returned but about and hour after the drive, it's still only showing like 12.15V. Is this just a bad battery or need more (proper) charging? In my experience, when any battery discharges and isn't recharged immediately a strong chance it won't, especially if it's two or three years old. I've used the Odyssey battery for years and keep them on float chargers (Battery Tender, NOCO) when not regularly used. Once they fail, they're gone. YRMV |
Jan 13 2026, 04:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,626 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
AGM batteries want to charge at higher voltage - 14.7v even up to 15v isn’t unheard of. The Volvo isn’t delivering enough voltage - guessing it is designed to handle Lead acid conventional battery.
Put on a charger that is AGM capable. Should be 12.7v at 90% state of charge. 12.1 is more like 60%. |
| fiacra |
Jan 13 2026, 05:18 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 672 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
I've had a different experience than Artfrombama with my Odyssey 925. My previous 914 sometimes sat for months between drives and I did not keep it on a maintainer since I had to park it in the driveway. I let it go dead multiple times, at least four times, and would pull it and put it on a charger overnight and it always came back to life. When I sold the car the battery was still going strong at 9 years old.
I would say that the jury is still out on your batteries. You need to put a full charge on them and see if they can hold it. I don't think it is fair to task your alternator to fully charge a dead or depleted battery, especially a big battery like this one. Get the right AGM battery charger, give them a good charge, and then test them. Hopefully they are fine. They are the only battery I use now, and nowadays I do keep them on a maintainer. |
| flipb |
Jan 13 2026, 05:35 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,863 Joined: 2-September 09 From: Fairfax, VA Member No.: 10,752 Region Association: MidAtlantic Region
Optima makes their own charger/maintainer that seems to be optimized for their AGM batteries. It's kept the red top in my 914 working for many years including months without driving during the winter.
https://www.amazon.com/dp/B00DHGPVKI?ref_=p...itle_5&th=1 |
| burton73 |
Jan 13 2026, 05:44 PM
Senior member, and old dude ![]() ![]() ![]() ![]() Group: Members Posts: 3,946 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California
My buddy Mark Sonners had a Red top in his 914 with a 2270 that would not take a full charge. He bought a battery conditioner, different than a TENDER and after a couple of days it came back 100% His Red Top was only 2 years old and sat for around 3 months.
Before the problem was the starter would not spin up. Good luck. Bob B |
| rick 918-S |
Jan 13 2026, 05:45 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,167 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I bought a battery tender from Harbor Freight last month for my optima red top. I had something draw it down to 5v. I had to keep starting the charger. It would bring it up a little at a time then shut down. When I got it upto 7.8v I put my big charger on it. The system i guess is to put the charger on one battery and use jumper cables on the second battery.
| Root_Werks |
Jan 13 2026, 06:05 PM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,877 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Run a PC925 in my Bug and PC1200 in my 914-6 for 5+ years. Really like the batteries. Don't know if you'll be able to pull the one back from 7 volts though.
Jan 13 2026, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 662 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Optima makes their own charger/maintainer that seems to be optimized for their AGM batteries. It's kept the red top in my 914 working for many years including months without driving during the winter. https://www.amazon.com/dp/B00DHGPVKI?ref_=p...itle_5&th=1 Also really like Optima products. Have used this exact same charger for years and it always does the job. It is a little unusual how you select the type of battery, but the charger starts with testing the battery (state of charge and type) then adjusts volts and amps throughout the charging process. |
| rjames |
Jan 13 2026, 10:58 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,422 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
The Odyssey PC925 needs a compatible charger to maintain it or it will die an early death. Ask me how I know. Get the right charger and it should last a long time. I've been very happy with mine.
All the links I can find for compatible chargers aren't working anymore. I'm using a Battery Minder 128CEC1, which was one the approved models. |
Lo-Fi Version | Time is now: 13th January 2026 - 11:15 PM |
