> Thick oil pump gasket, Pump doesn’t line up
Chad911sc
post Jan 17 2026, 10:26 AM
So my plan was to start assembling the 2056 today, but I found this when placing the oil pump into the case. I measured the gap needed to fill with a gasket, and it’s right at 3mm. Do they make a thick pump to case gasket that will fill this space, so that the rubber sealing ring will be in the case instead of hanging out the back of it??
The gaskets that came with the pump are way to thin to place the pump in the correct position.
fixer34
post Jan 17 2026, 02:30 PM
I don't think you should need a 3mm thick gasket, the paper style is normal.
Either the pump is machined incorrectly or the mounting surface was milled way too much. Hoping it just a bad pump...
Geezer914
post Jan 17 2026, 02:40 PM
Geezer914
Check the clearance to the cam gear with the cam installed.
post Jan 17 2026, 03:03 PM
That groove tawards the inside doesn't look like an O-ring groove, if this is what you are thinking about. (IMG:style_emoticons/default/confused24.gif)
Ninja
post Jan 17 2026, 04:59 PM
I'd check the line up of the oil pump ports to case too.
Might add clarity as to proper depth.
I'd prefer the holes in the pump line up perfectly with the holes in the cases.
Chad911sc
post Jan 17 2026, 05:26 PM
So the pump body is definitely too long. It’s just shy of 2mm longer than the previous pump that came out of the running motor. I have sent pictures and explanation to the company I bought it from. The boss on the back of the pump where the gear engages the cam gear is also a hair longer as well. It bottoms out against the cam as you can see in the first pic.
post Jan 18 2026, 02:54 PM
QUOTE(Chad911sc @ Jan 18 2026, 11:26 AM) *
Now that looks better ,that new pump is clearly wrong as is the machined ? 'o'ring groove as mentioned it is a mess and not cut right on the wrong pump besides.
Believe your oil pressure issue was a bent crank so I would say you will be fine using the pump that fits properly if it is in good condition ,good luck as appears like you need some after your hassles ,cheers.
Chad911sc
post Jan 19 2026, 09:40 AM
Yes, I think I will be ok using the non o-ringed pump since the issue was the out of round crank. I was just trying to knock out every source of oil pressure issue while having it apart. I guess the oil pumps from Low budget VW are type 1 only and do not fit in the type 4 cases. Just a heads up for the next guy that as far as I can find, no one makes a o-ring pump for the type 4 engine.
I’m not sure what oil pump this was that was in the engine previously, so I will just order a 26mm CB maxi pump and put it in when it arrives.
post Jan 19 2026, 10:39 AM
Gene Berg still makes o-ringed type 1 oil pumps (hard anodized too):
https://www.geneberg.com/product_info.php?c...products_id=384
Not home right now, so can't measure any Type IV cases to see if there are differences between any of them. Just a guess,, but maybe that low bugget pump used a dished cam oil pump body and not a flat cam one?
Chad911sc
post Jan 19 2026, 11:46 AM
I looked on the Gene Berg site earlier today because I thought I had remembered someone in the past saying they had them, couldn’t find it. But there it is! I think that is the route I would like to go, because I want to take all the precautions I can to keep the idle pressure up.
Not sure about the dished cam idea, but the pump doesn’t line up with the oil ports either. If you pull the pump back so that the o-ring is in the proper place inside the case, then the ports line up correctly also. But you then have that 3mm gap between the pump and the case itself. I don’t understand why it’s so off because it is a type 1 pump. The circumference is spot on. It’s a 30mm Schadek type 1 pump that was modified by low budget VW.
I don’t get it either??
stownsen914
post Jan 20 2026, 08:17 AM
I've understood that type 1 pumps require machining to fit into a type 4. Not sure about the length of the pump body, but I believe one of the areas that needs to be addressed is the alignment of the oil ports as you've noted.
- Lo-Fi Version Time is now: 20th January 2026 - 09:26 AM
