| nmkimosabe |
Jan 19 2026, 03:51 PM
Newbie ![]() Group: Members Posts: 4 Joined: 16-March 25 From: Santa Fe, NM Member No.: 28,660 Region Association: Rocky Mountains |
I'm looking for a used OEM door check strap that is fully operational. If anyone has one please let me know. My usual source is sold out and don't want to buy a URO part. Appreciate it.
| L-Jet914 |
Jan 19 2026, 05:05 PM
Member ![]() ![]() Group: Members Posts: 377 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
I'm looking for a used OEM door check strap that is fully operational. If anyone has one please let me know. My usual source is sold out and don't want to buy a URO part. Appreciate it. 914Rubber sells a rebuild kit if this is what you're looking for. https://914rubber.com/door-stay-rebuild-kit-for-porsche-914 |
| bdstone914 |
Jan 19 2026, 06:58 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,236 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm looking for a used OEM door check strap that is fully operational. If anyone has one please let me know. My usual source is sold out and don't want to buy a URO part. Appreciate it. 914Rubber sells a rebuild kit if this is what you're looking for. https://914rubber.com/door-stay-rebuild-kit-for-porsche-914 In my opinion you are better off with a good used strap. I found several issues with their kit. They click. Hole size was oversized and pin did not fit the holes in the body. That was years ago and I don't know if they improved them. |
| L-Jet914 |
Jan 19 2026, 07:46 PM
I'm looking for a used OEM door check strap that is fully operational. If anyone has one please let me know. My usual source is sold out and don't want to buy a URO part. Appreciate it. 914Rubber sells a rebuild kit if this is what you're looking for. https://914rubber.com/door-stay-rebuild-kit-for-porsche-914 In my opinion you are better off with a good used strap. I found several issues with their kit. They click. Hole size was oversized and pin did not fit the holes in the body. That was years ago and I don't know if they improved them. I am going to have to check the kit I bought back in 2024 that I have yet to get around to, to see if there are any issues with the machining quality that mentioned. |
| smg914 |
Jan 19 2026, 08:00 PM
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,980 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
Their pin still doesn’t fit.
| bdstone914 |
Jan 20 2026, 01:25 AM
I'm looking for a used OEM door check strap that is fully operational. If anyone has one please let me know. My usual source is sold out and don't want to buy a URO part. Appreciate it. 914Rubber sells a rebuild kit if this is what you're looking for. https://914rubber.com/door-stay-rebuild-kit-for-porsche-914 In my opinion you are better off with a good used strap. I found several issues with their kit. They click. Hole size was oversized and pin did not fit the holes in the body. That was years ago and I don't know if they improved them. I am going to have to check the kit I bought back in 2024 that I have yet to get around to, to see if there are any issues with the machining quality that mentioned. Also check the arm as it should be knurled. The shape was different and clicked unlike the original arm. . It is the rollers that go bad and I think they are the only part that seemed OK. And maybe the springs. |
Lo-Fi Version | Time is now: 20th January 2026 - 09:29 AM |
