> Hell Hole Repair
burlybryan
post Jan 20 2026, 08:48 AM
Pulled the engine for an eventual 2.0 replacement and tackling my laundry list of "while it's out" tasks. Hell hole is the first up. Made good progress on cutting out the old rusted portion of the engine shelf and revealing the rot.
I'm of two minds on the patch panels. The perfectionist in me wants to cut out sections back to clean metal and flush patch, but access is a pain for available cutting tools. The lazy rationalist in me says that the car isn't perfect anyway and to make a U shaped panel that conforms to the firewall section, runs across the wheel well and up the long. Easier to plug weld then stitch and better overlap with good metal.
Any suggestions?
post Jan 20 2026, 09:06 AM
I think you already know the answer; do it once, do it right and never worry about it again. As this is a extremely common issue, most people looking for a 914, focus on this area first. Let your perfectionist nature run free here. (IMG:style_emoticons/default/beerchug.gif)
Geezer914
post Jan 20 2026, 09:58 AM
Geezer914
Cut out the bad metal, repair panels are available. Do it right the first time!
SirAndy
post Jan 20 2026, 11:38 AM
Resident German
QUOTE(Geezer914 @ Jan 20 2026, 07:58 AM) *
Also, there most certainly will be rot inside the long underneath.
If you haven't seen this thread already, it's a good read about what is most likely hiding in there and how to fix it correctly:
http://www.914world.com/bbs2/index.php?showtopic=16748
(IMG:style_emoticons/default/bye1.gif)
burlybryan
post Jan 20 2026, 01:16 PM
Ok, got it. Thanks for the inspiration. Flush (and layered on the long) it is.
I have to do the rear floor pan anyway, so that makes the firewall section easier anyway.
post Jan 20 2026, 02:29 PM
Good luck on your rustoration. (IMG:style_emoticons/default/smash.gif)
Be ready for a lot more “while I am in there moments”! (IMG:style_emoticons/default/smile.gif)
Share your progress here. I personally find it therapeutic in keeping me motivated in my project and it’s nice to see others sharing the same journey. (IMG:style_emoticons/default/rolleyes.gif)
trojanhorsepower
post Jan 20 2026, 02:31 PM
Agree with the others. Do your homework. IT can be done.
Sir Andy: Thanks for linking Michelko's thread. I had not seen it in years, and its a great example of how to do this right.
- Lo-Fi Version Time is now: 21st January 2026 - 12:16 PM
