> 914/4 to 914/6, which flywheel/clutch
Lars OLesen
post Jan 25 2026, 03:03 PM
Hello all you very wise guys..
I have a 914/4 1974 2,0 that I´m collecting parts for a 2,7 /6 conversion for.
Which flywheel and clutch will be best, and easiest to fit my conversion?
Regards all the way form Denmark..
Lars
Steve
post Jan 25 2026, 07:17 PM
QUOTE(Lars OLesen @ Jan 25 2026, 01:03 PM) *
Lars
Change the flywheel on the 2.7,to a 911 2.0 flywheel and use a standard 911T 2.0 disk and pressure plate. This is the same disk and pressure plate used on the 914-4 2.0. I ran this on my 2.7 over 20 years with no slippage or other issues.
IronHillRestorations
post Jan 26 2026, 08:28 AM
I. I. R. C.
Using a ‘ 69 911 or 914-6 flywheel is the most straightforward way. Just be aware that when using it on a 2.4 or 2.7 the TDC and timing marks on the rim of the flywheel will be off, as those crankshafts are indexed differently. You can use the timing marks on the pulley to re-mark the flywheel.
post Jan 26 2026, 09:57 AM
QUOTE(IronHillRestorations @ Jan 26 2026, 09:28 AM) *
This is how we managed this, worked perfect
- Lo-Fi Version Time is now: 26th January 2026 - 05:23 PM
