| porsche-racer |
Jan 25 2026, 05:25 PM
Newbie ![]() Group: Members Posts: 4 Joined: 14-December 25 From: Orange County Member No.: 29,153 Region Association: Southern California |
I am the lucky new owner of this 1972 E Production 914-4 race car. The car was sold new and modified by Wester Porsche-Audi in Monterey, CA. The car was raced from 1977-1992 by Scott Brinker out of Fresno, CA. The car was then raced sparingly by Spencer Harris of Bakersfield, CA until 2018.
I am hoping some here has some SCCA finishing results, entry forms and photos of this car. Attached image(s)
| GregAmy |
Jan 25 2026, 05:49 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,623 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Do you have the SCCA logbooks? The back of the first book should have the original logbook owner listed. And if you go through the pages you should be able to find venues, dates, and possibly results (if the owner added them, though that seems to piss off some tech inspectors for some reason...)
If you don't have the logbook, get for me the logbook number, which should be stamped somewhere on the right main hoop. It will be a two digit number followed by four or five digits. I can scour records and/or make some contacts to see if the original-issuing region has info. GA, long-time SCCA competitor, steward, scrutineer... |
| porsche-racer |
Jan 25 2026, 05:53 PM
Do you have the SCCA logbooks? The back of the first book should have the original logbook owner listed. And if you go through the pages you should be able to find venues, dates, and possibly results (if the owner added them, though that seems to piss off some tech inspectors for some reason...) If you don't have the logbook, get for me the logbook number, which should be stamped somewhere on the right main hoop. It will be a two digit number followed by four or five digits. I can scour records and/or make some contacts to see if the original-issuing region has info. GA, long-time SCCA competitor, steward, scrutineer... Greg, Sadly the log books are lost. I will report back with a roller number. Thanks for the reply and offer to help! |
| stownsen914 |
Jan 27 2026, 09:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 977 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
Cool car. And looks to be in impressively good condition given its age. I went through a similar exercise several years ago with a 1980s EP 914, with almost no info aside from pics of the car, and an SCCA historian was able to provide a bunch of info on the car and owner/driver. I see Greg has already responded - he'll get you in the right direction.
| rgalla9146 |
Jan 27 2026, 10:32 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,916 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
E prod cars had to keep four lug brakes /wheels ? |
| GregAmy |
Jan 27 2026, 11:00 AM
E prod cars had to keep four lug brakes /wheels ? Struts, hubs, rotors, and wheels are unrestricted in Full Prep Production so I suspect that's the situation. They even allow non-stock calipers now. I remember looking through this issue some years ago when I learned about the Ginther 2L 4-banger 914s in D Prod. I noticed those had 5-bolt wheels and I went through a rabbit hole of old regs trying to work it out. I couldn't find any regs earlier than the 2000s but even back then hubs were "unrestricted". Hey, "unrestricted" is unrestricted... |
| brant |
Jan 27 2026, 12:42 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,129 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
A car like this is light.... and surely had a race motor... but still a small displacement 1.7
didn't need huge brakes 4 bolt brakes are very very adequate for 4cylinder power. its the street crowd that pushes bigger brakes and its just dead weight if you don't need it. some of the best PCA races I've ever done were against people on stock 4 bolt brakes braking just slows you down racers try to brake as little as possible 4 bolt stuff is entirely adequate in an EP class |
| Unobtanium-inc |
Jan 27 2026, 01:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,412 Joined: 29-November 06 From: New York Member No.: 7,276 Region Association: None
Have you talked to Spencer's widow? She's still around and pretty cool. He was pretty cool too.
Attached thumbnail(s) |
| GregAmy |
Jan 27 2026, 01:47 PM
didn't need huge brakes My ex-ITA racer with a WAG'd 150hp weights 1920 without me in it. The brakes on that car seem quite adequate (I use Hawk pads, usually Blue). But I can see in context why a racer would want to change over, mostly due to the better availability, development, and options for 911 suspension, brakes, and wheels. If I were building a serious run at EP I'd probably do it. |
Lo-Fi Version | Time is now: 27th January 2026 - 09:47 PM |
