| Cfletch |
Jan 25 2026, 07:38 PM
Member ![]() ![]() Group: Members Posts: 223 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
Hey there everyone, Newbie to Cam timing in general and working on putting the engine back together after repairing an oil leak from the Cam Thrust Plate o rings.
I am having what I hope is just a simple issue of misunderstanding on the timing of the cams and can use some help. Engine is a 1974 2.7 CIS that retains the stock camshafts: L:911.105.141.00 R:911.105.142.00 I currently am running into an issue where I am unable to get more adjustment out of my cam because I am hitting the piston with the valves when trying to rotate it in either direction. Current process has been having the engine at Z1, having my distributor facing #1 cyl and having my piston at the top of the stroke confirmed by a whistle adaptor in the cylinder. Camshaft have the "911" at 12 o clock and the part number listed at 6 o clock. I have my #1 Intake Valve installed and set to correct valve clearance and have the timing chains tensioned by the stromksi tensioners. Pin is installed and nut is snugged up to the cam to get a reading for when rotating the engine. I have a drop gauge and z bar set up on the #1 intake valve and when rotating the engine over, the valve does not seem to lift at the correct position on the crank, and I am also not able to get the same lift I once had of 3745 Thousandths. I would like to rotate the cam at this point to get it adjusted slightly to get it to start raising at a better time relative to the crank, but when attempting to rotate it, I can feel interference with the valve and piston. I feel this going either clockwise or counterclockwise. I am stuck at this point and called it for the day and am looking for some help here. Based on various videos and my 911 rebuild book from Wayne Dempsey. I seem to be doing everything correct, but just am not getting it to raise the correct amount and when trying to adjust the cam I run into clearance problems with the valve so I am clearly not in the right spot there. I am looking for any guidance here either in text format or possible a phone call tomorrow to walk through stuff. I have everything more or less set up ready to go and this is my last step before I am able to get it buttoned back up and reinstalled into the car. One thing I had noticed is that we were getting relatively close to the expected measurement, but it was very far away from, Z1, probably about ~100 off from where it would be expected. Today I had the help of Robert A, he drove up and we worked on repairing the leaky seals but had ran out of sunlight and time today. He left me his tools to hopefully wrap this job up and we were both stumped on this after a long day of work. Any help is most appreciated! |
| rudedude |
Jan 25 2026, 09:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 544 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I don’t know your cam stamping but the key slot should be facing up at z1
| Cfletch |
Jan 25 2026, 09:13 PM
| rudedude |
Jan 25 2026, 09:21 PM
Could you have switched sides? Left 1-3, has the further lobe separation
| rudedude |
Jan 25 2026, 09:33 PM
Are you using z1 on the pulley or flywheel? The z1 mark on my 2.0 flywheel is some 40 degrees off z1 on the pulley
| Robarabian |
Jan 25 2026, 09:38 PM
914 A Roo ![]() ![]() ![]() Group: Members Posts: 737 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California
Not possible.
We only removed one cam at a time. We removed the 1,2,3 side first, removed the cam chain housings, changed the gaskets / seals, and re-installed that cam. Then we did the 4,5,6 side. We thought we were being smart and measured the overlap prior to tearing into it, so we could replicate it. Now we cant for some reason. The overlap it had was slightly off from the book (Colin, you can speak to this) so we will approach it from the "book spec" versus what we measured with the stomski setup prior to removing it all. Z1 on power stroke. Turn the crank and the overlap is not coming on til we are just about at TDC and the numbers rise After TDC. My experience has always been that the overlap happens prior to TDC.. hence the "overlap." The keyways were facing up both sides when we index the cams. On his cams, the part number is on the bottom, "911" is on top and I think there is a small dot as well. Could you have switched sides? Left 1-3, has the further lobe separation |
| sixnotfour |
Jan 25 2026, 11:21 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,107 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
If #1 is at TDC and rotor pointing at firing #1..It should be on compression stroke intake valve closed ..
and # 4 will be at overlap.. |
| sixnotfour |
Jan 25 2026, 11:29 PM
0.03745 ??? #1 at overlap Rotor pointing to #4 at z1
| sixnotfour |
Jan 26 2026, 03:33 AM
Is .3745 total lift ? (IMG:style_emoticons/default/idea.gif) (IMG:style_emoticons/default/popcorn[1].gif)
| rudedude |
Jan 26 2026, 07:06 AM
My spec book is in the shop but I suspect a cis cam would have about 1mm overlap when timed at z1 for #4 for #1. It will have more lift but not at z1
| DennisV |
Jan 26 2026, 08:29 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 846 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Hey there everyone, Newbie to Cam timing in general and working on putting the engine back together after repairing an oil leak from the Cam Thrust Plate o rings. I am having what I hope is just a simple issue of misunderstanding on the timing of the cams and can use some help. I am looking for any guidance here either in text format or possible a phone call tomorrow to walk through stuff. I ran into issues with my first cam timing as well. These few videos helped me. There is more than one way to approach it, and I found one more intuitive than the other. Mastering Valve Train & The Art Of Porsche 911 Cam Timing Timing Camshafts on a Porsche 911 Engine How To Set Porsche Cam Timing Cam timing & valve overlap basics tutorial Also make sure you're setting the timing that corresponds to the grind on your cam shafts. Kurt at Klassik ATS offers hourly consultations. I've been impressed with his videos and posts. |
| sixnotfour |
Jan 26 2026, 08:50 AM
My spec book is in the shop but I suspect a cis cam would have about 1mm overlap when timed at z1 for #4 for #1. It will have more lift but not at z1 @dennisv yes he needs to watch some more ...examples of how to.. |
| Robarabian |
Jan 26 2026, 09:17 AM
I think he meant .374. the dial gauge is digital and indicated a fraction, meaning almost .375.... And if I remember, the 4,5,6 bank was timed at the higher end of the spec before we disassembled it, around .390. 0.03745 ??? #1 at overlap Rotor pointing to #4 at z1 |
| sixnotfour |
Jan 26 2026, 09:20 AM
I think he meant .374. the dial gauge is digital and indicated a fraction, meaning almost .375.... And if I remember, the 4,5,6 bank was timed at the higher end of the spec before we disassembled it, around .390. 0.03745 ??? #1 at overlap Rotor pointing to #4 at z1 that's not overlap.... |
Lo-Fi Version | Time is now: 26th January 2026 - 05:22 PM |
