| Flyinlow |
Jan 29 2026, 05:29 PM
Flyinlow ![]() ![]() Group: Members Posts: 114 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
74 2.0 project nearing completion testing things out then….hook up battery headlights go up but not on switch on lights close and turn on also-brake lights on when key on… got something wrong
| bkrantz |
Jan 29 2026, 07:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,587 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
Did you unplug all the leads on the fuse panel during the rebuild?
| bkrantz |
Jan 29 2026, 07:34 PM
Check the brake pedal switch. From memory, it has a lever that is pushed to open the circuit when the pedal is at rest.
| Spoke |
Jan 29 2026, 11:17 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,331 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
| Flyinlow |
Jan 29 2026, 11:39 PM
hook up battery headlights go up but not on switch on lights close and turn on This is the circuit for the headlight motors. It sounds like the wires to the headlight motors is reversed likely at the headlight switch. Anyone have a pic or a layout for that switch?theres a lot of wires on it I do not recall unplugging any |
| Spoke |
Jan 29 2026, 11:50 PM
Here's a thread with info on the headlight switch connections.
Seems like the wires on 30B and 56K are reversed. 1974 Headlight Switch pinout |
| Spoke |
Jan 30 2026, 12:08 AM
A fuzzy schematic showing the connections for the motors at the headlight switch.
| Flyinlow |
Jan 30 2026, 10:36 AM
| ClayPerrine |
Jan 30 2026, 05:55 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,541 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
There is a complete explanation of how the headlights work here:
http://www.914world.com/bbs2/index.php?showtopic=20605 |
Lo-Fi Version | Time is now: 31st January 2026 - 05:21 AM |
