| FlacaProductions |
Feb 2 2026, 10:00 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,135 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Greetings - please move this if needed as it's not truly a 914 question but I think the general knowledge translates.
This is a pic of the shift coupler on my 67 911. am I incorrect in assuming the center pin should stretch across and fully seat inside both bushings? It actually looks like the center pin is too short as it's flush on one side but not the other. I was in there to adjust the throw as I'd like to not have to reach quite so far for 2nd and 4th when I saw it. I've only had this car since April so I'm still in the getting-to-know-you phase... Thanks! b |
| FlacaProductions |
Feb 2 2026, 10:01 AM
| eradon |
Feb 2 2026, 10:35 AM
Newbie ![]() Group: Members Posts: 2 Joined: 26-May 24 From: germany Member No.: 28,151 Region Association: None |
This pin is not only to short, it is also to small.
There should be no gap. ![]() |
| 914Sixer |
Feb 2 2026, 11:09 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,402 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes TOO short. On a side bar note, looks like you have OVAL bushings, adding to sloppy shifting
| dr914@autoatlanta.com |
Feb 2 2026, 11:40 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,231 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
yes the one in there is too short
Greetings - please move this if needed as it's not truly a 914 question but I think the general knowledge translates. This is a pic of the shift coupler on my 67 911. am I incorrect in assuming the center pin should stretch across and fully seat inside both bushings? It actually looks like the center pin is too short as it's flush on one side but not the other. I was in there to adjust the throw as I'd like to not have to reach quite so far for 2nd and 4th when I saw it. I've only had this car since April so I'm still in the getting-to-know-you phase... Thanks! b |
| FlacaProductions |
Feb 2 2026, 02:29 PM
Ok. How would it be too short? Where would it have come from?
I do have ovals in there and have a new coupler coming with ovals as well since this is a 911 - and a very stock one. I’m doing my best to keep it that way. 914 bushings were/are round - 911s of the same era are oval. Thanks for confirming my suspicions. |
Lo-Fi Version | Time is now: 3rd February 2026 - 05:59 AM |
