| krazykonrad |
Feb 3 2026, 12:49 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,163 Joined: 21-February 06 From: Canton, GA Member No.: 5,610 |
I'm about to run my rocker arms/shafts/etc. through the ultrasonic cleaner. Will Simple Green work? I've had Simple Green eat up the protective finish on bike chains. Any issues with engine parts?
Thanks, Konrad |
| GregAmy |
Feb 3 2026, 01:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,627 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
I used Simple Green Pro HD when I rebuilt the Dellortos. Worked great.
https://www.homedepot.com/p/Simple-Green-Pr...13421/100550784 |
| Chad911sc |
Feb 3 2026, 01:59 PM
Member ![]() ![]() Group: Members Posts: 260 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Purple stuff and water works great too.
Feb 3 2026, 03:32 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 693 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Question: in your experience, what shouldn't you use the ultrasonic cleaner on?
For example, going to clean up some 914 door handles, but don't want to make them look ugly or the chromed parts ruined. Have used some rust treatments in the past that left the steel blackened. |
| 914sgofast2 |
Feb 3 2026, 05:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 788 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
You can also use plain old Dawn dishwashing liquid soap from the kitchen in the ultrasonic cleaner. Works well to remove oil and grease without discoloring the metal parts. Simple Green has a tendency to blacken aluminum parts and pot metal parts in my experience. Dawn stop is also cheaper than any of the other cleaners mentioned, but may take a bit longer to effectively clean off all the oil crusted and baked on the parts.
Lo-Fi Version | Time is now: 4th February 2026 - 08:44 AM |
