> Broken Hand Brake
LefthandRev
post Feb 5 2026, 01:30 PM
Hi, all.
I pulled my hand brake to park on a hill. When I pulled it up, the button, shaft, and spring shot out like a rocket. No more hand brake! Started looking closer at it and there doesn't seem to be an easy way to fix or replace it - the brake is riveted to the tub and the fatigued shaft just gave up the ghost.
What options do I have here?
It's a '74, if that matters.
Spoke
post Feb 5 2026, 02:06 PM
Jerry
Everything wrt the e-brake comes off with nuts and bolts. Figure out what part broke and replace it.
A single cable from the handle goes to an equalizer to 2 cables; one to each side. Might be time to inspect and replace any other components which look worn/broken.
- Lo-Fi Version Time is now: 5th February 2026 - 09:59 PM
