| drem914 |
Feb 10 2026, 12:10 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,067 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California
I am currently starting a refurbishment of a combo fuel and temp gauge for my 914.
The cellophane for the low fuel light is faded and the red/orange needles are faded. Where have you gotten the paint? Are you just using Testors model paint by hand or spray painting? Also, where have you located the red/orange cellophane? |
| FlacaProductions |
Feb 10 2026, 08:09 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,150 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
check this thread - my two links for the low fuel lighting gel are still good.
http://www.914world.com/bbs2/index.php?s=&...t&p=3170356 lighting gel: https://www.stagelightingstore.com/41-Salmon https://www.bhphotovideo.com/c/product/4434...ter_Salmon.html |
| worn |
Feb 10 2026, 08:16 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,546 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
check this thread - my two links for the low fuel lighting gel are still good. http://www.914world.com/bbs2/index.php?s=&...t&p=3170356 lighting gel: https://www.stagelightingstore.com/41-Salmon https://www.bhphotovideo.com/c/product/4434...ter_Salmon.html I have used the photographic gel filters. You can also go buy plastic report covers at an office store. |
| Shivers |
Feb 10 2026, 09:10 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,257 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
I just did my speedo, purchased some expensive gauge needle paint that came in a tiny glass vile. I followed the directions, I think now I would have gotten a better finished product just using testors. I would suggest calling North Hollywood speedo or one of the others and see if they will sell you some paint for your needles.
| dtmehall |
Feb 10 2026, 09:17 PM
Member ![]() ![]() Group: Members Posts: 240 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
North Hollywood speedo is the best for restoration, if you don't want to do it yourself
depends on the $ that you have |
| Montreal914 |
Feb 10 2026, 10:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,026 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
North Hollywood speedo is the best for restoration, if you don't want to do it yourself depends on the $ that you have There are other options too... Check out the work John Bell does. (IMG:style_emoticons/default/wink.gif) ... for example the very nice gauges he did for @mepstein . (IMG:style_emoticons/default/drooley.gif) |
| FlacaProductions |
Feb 10 2026, 11:56 PM
Joe’s Speedometer
6704 Tampa Ave Reseda , CA 91335 818-468-4414 Joe Torossian is a great guy and does top work. |
Feb 11 2026, 06:14 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,433 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
North Hollywood speedo is the best for restoration, if you don't want to do it yourself depends on the $ that you have There are other options too... Check out the work John Bell does. (IMG:style_emoticons/default/wink.gif) ... for example the very nice gauges he did for @mepstein . (IMG:style_emoticons/default/drooley.gif) I couldn't be happier with John's work and the way he does business. I've used the big shops but have no reason now that John is my gauge guy. I don’t think John sells supplies. |
| Shivers |
Feb 11 2026, 10:00 AM
I can share something that did work out, the needle ended up darker but the bezel pieces came out great with this paint. Here is a pic of the speedo I did and the tach that came restored.
@drem914 |
| drem914 |
Feb 11 2026, 07:03 PM
Thank you for all the great information. Luckily, I can take my time as I am refurbing an extra gauge and will swap in when complete.
Lo-Fi Version | Time is now: 12th February 2026 - 10:10 PM |
