> LM-1 Data log, MPS/AFR
rfinegan
post Feb 13 2026, 01:24 PM
I wired up the O2 and the LM-1 with a new Tach channel (I need a TPS for throttle position/load next)
I think this a a cruise speed , with a little more throttle in near the end.
The full stop (3/4 to wot)seems to be about 12.1 or so ( I am liking that ok) NOT SEEN ON THIS SESSION
MPS looks lean on cruise/ part load
Head temp gets hot on light cruise about 60 MPH
This tool seems to have a lot of features for the $$$ and still works well for being so OLD!
Maybe some decel/over run here too on the graph, I need t make notes on the recordings, not EZ for 1 person that is the driver.
rfinegan
post Feb 13 2026, 01:30 PM
or maybe use a old school vac gauge. :think
rfinegan
post Feb 13 2026, 01:40 PM
QUOTE(rfinegan @ Feb 13 2026, 02:30 PM) *
A little tweek to the part load (middle Screw CCM Loosen) 1/8 turn to start?
I just need to get her road worthy, While I work on my Clewette/ Electromotive TechGT 2056
Ninja
post Feb 13 2026, 03:52 PM
15.8 would bug me. I'd prefer 13.8-14.5 cruise and I'd want to know if 13.8 reduced cylinder heads temps versus 14.5.
3/4 throttle I'd want 12.5 or lower, once again I'd be looking at temp data here too.
In my book 16 is "lean burn" beginning. On a water-cooled engine I'd want port injectors, modern digital FI, COP, and knock sensors. I would not be looking for power here, just fuel economy.
I wouldn't run 16-1 on anything built in the 70s without fully updating everything and I'd still be more conservative and lean towards the rich side of things.
Ishley
post Feb 13 2026, 03:56 PM
I integrate O2 data that I capture on my PC with 123+ Distributor data captured on my phone simultaneously . You have to have the blue tooth version of the 123. Using time stamps form each source I can connect the data. I chart it and can see where I go lean and look at the other variables for why... and can make tweeks to the MPS from there.
Just another option to fill in the picture using data.
brant
post Feb 13 2026, 04:12 PM
Set your redline mixture for 13 or 13.5
Then mid range
Too lean right now.
rfinegan
post Feb 15 2026, 09:05 AM
Thanks for the tips everyone....
I made the first adjustment, only took 15 minutes tops!
Some time today I record and cruise/ part load and 3/4 load. Ill use 4 th gear for this run for the new base lines
Fingers Crossed
TRP
post Feb 15 2026, 10:03 AM
Super cool to see this coming together.
rfinegan
post Feb 15 2026, 10:38 AM
Update :
Preface
This was one of the BEST COLD start 50 degree day test drives in some time. 10-15 sec warm up and start driving....warm up drive /transition was with out issue with nothing to note.. heater start pushing heat by front of subdivision. On the connecting 2 lane highway, 5 gears "normal acceleration was good and cruising @ 60 ish in 5th.....Good to decent head temps about 375 ish (-25f for the Old VDO) make me fell ok with this adjustment...
Here is the log for a steady cruise at 60 MPH /5th Gear. Mostly flat road with a few minor hills
Focus on flat RPN at 35 sec mark. AFR = 15.2/15.4.
Odd the Rpm is still giving me issues with real rpm but we will follow up on that
Graf to follow ...would not upload
rfinegan
post Feb 15 2026, 11:16 AM
Oh the tool has a calibration setting for the Tach/accessory. This is a new inductive PU from Innovate and my old one was a recouped part and did not recalibrate to the new one.. ;-)
- Lo-Fi Version Time is now: 16th February 2026 - 01:16 AM
