> Cooling Fan Balance Questions
aggiezig
post Feb 18 2026, 11:56 AM
Porsche Wannabe
Does anyone happen know how the cooling fans were balanced from the factory?
I took mine apart to refinish (Cerakote!) and very stupidly did not make any index marks for the front "ring" and back fan. I noticed on reassembly that there is a weight crimped under the ring lip, presumably for balance. I'm wondering if these pieces were balanced independently (unlikely) or as a unit...
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.1.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.2.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.3.jpeg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-19557-1771437363.4.jpeg)
Any ideas from 914world on how I may find the right orientation / re-balance? My local machine shop said no dice as far as fitting it on any of their machines (ID of the fan shroud bore is too small).
post Feb 18 2026, 12:34 PM
I'd bet the assembly was balanced, have you sent the crank for balancing?
post Feb 18 2026, 02:26 PM
QUOTE(aggiezig @ Feb 19 2026, 12:56 AM) *
Don’t know what those last couple sentences mean.
It’s a very good idea to balance everything in your motor that rotates. Flywheel, crankshaft, rods, pistons/rings/pins, etc. That means get that fan balanced. Have seen pictures of an exploded fan and it’s not something you’ll enjoy. Dynamic balance all of it and if your shop can’t or won’t do it, send to someone who can (DPR?).
mgphoto
post Feb 18 2026, 04:34 PM
If you took the fan apart and didn’t assemble it the exact same way then you have to rebalance the fan, I would include the hub, crank and the rest of the rotating assembly.
post Feb 18 2026, 05:09 PM
In addition to balance the ring has to be centered on the fan or it will rub the shroud.
Test fit it and see if it clears. If not loosen the bolts and teap the ring until you have equal clearance on all sides
TRP
post Feb 18 2026, 05:20 PM
Oh man, I was going to do the same thing with my fan (Cerakote), but I wanted to figure out how to make sure it was indexed the right way afterwards. In the end I kind of looked at it and said "it'll be fine all dirty".
I did notice that my fan doesn't have any of the timing marks on it, that seems like it's going to be a problem.
post Feb 18 2026, 05:25 PM
QUOTE(bdstone914 @ Feb 18 2026, 06:09 PM) *
changing the relationship between the hub (fan) and the pulley will affect the balance. It's possible everything will be fine, but it's a gamble. Yes, the clearance must be equal
stownsen914
post Feb 19 2026, 09:11 AM
See if you can find any witness marks on the fan for where that crimp was located previously. It may tell you how to clock the fan belt ring.
Also look on your crank where that nub on the bolt triangle was on the crank. It could tell you the correct orientation to bolt the fan to the crank.
Hard to know how everything may have been balanced in the past, but putting it back the same way it was before would be a safe bet.
post Feb 19 2026, 09:51 AM
QUOTE(stownsen914 @ Feb 19 2026, 10:11 PM) *
Have "built" VW motors in years past without balancing because $$ was tight and didn't have the ability/equipment to do so. Would not build a motor today without dynamically balancing it.
Just bolting parts together and hoping it is balanced is not a "safe bet" nor is it prudent, especially if you plan to wind it up and spin it fast. In the end and over the expected life of your motor, dynamically balancing your motor isn't that expensive anyway. Do it right and you'll have a smooth running motor that will last a long time (everything else done right). Running an out of balance motor is asking for trouble and a reduced lifespan. YMMV.
rfinegan
If no one can Zero balance the fan, I would suggest static Balance like a mower blade or wheel/tire. That will get you close.
Then do a dynamic balance with the crank, hub, flywheel and pressure plate. Along with the internal components balance to match each other.
stownsen914
post Feb 19 2026, 10:05 AM
QUOTE(Jack Standz @ Feb 19 2026, 10:51 AM) *
Generally agree. But if the motor isn't apart (was unclear if OP's motor is apart, I may have missed that detail) ... not sure I'd take it apart just to balance the fan if I could figure out how to put it back the same way it came apart.
Ninja
post Feb 19 2026, 10:25 AM
That is a neutral balance part; doesn't have a dedicated offset weight.
Any decent balance shop should be able to balance that fine alone.
Edit: As long as they have a method of chucking it up on the balancer, this might be an issue.
On a neutral balance engine proper balancing technique is to balance everything separately THEN bolt it all together and recheck/rebalance.
Most of the time, the crankshaft is balance first, balancer is bolted on and balanced then removed, flywheel is bolted/balanced, followed by pressure plate ALONE.
If a balance shop wants to balance with the disc installed run like HELL!
The disc is considered to be part of the transmission for balancing purposes.
Then it's all bolted together. If it was really done right, it should be CLOSE!
If you're off a little bit do a final assembly adjustment.
If it's a bunch recheck each part to see where you botched it!
The above way is more expensive than merely balancing the assembly as a single piece but allows individual parts replacement (flywheel/clutch/balancer).
On something I cared about I'd have that fan balanced after verifying correct outer ring placement.
1 Members: mgphoto
- Lo-Fi Version Time is now: 19th February 2026 - 09:49 PM
