| TRP |
Feb 23 2026, 03:02 PM
Member ![]() ![]() Group: Members Posts: 220 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Hey Gang!
As I have shared, I'm having a 2056 built for my 914, bumping up from the 1.8. For this build, I upgraded to new casting 2.0L heads (stock 2.0 valve sizes), and the larger 'gowesty' throttle body. - With the larger displacement, the larger valves, and the larger throttle body? - Do I need to be concerned with the size of the intake snorkel from the 1.8 air cleaner? - If I were to consider enlarging the diameter of the air intake snorkel, do I need to consider the shape (tapered from smaller 40mm opening up too 63.5/64mm at the air box? Maybe I'm over thinking all of this and the impact would be negligible for daily driving/spirited back roads? The intake snorkel is circled in red below: ![]() Thanks, Ted |
| wonkipop |
Feb 23 2026, 04:03 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,418 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
if you are worried about air flow to the engine perhaps the air filter element itself might be the place to look. instead of the paper element you might be able to use a higher flow K+N style high flow cotton filter. these days you seem to be able to get them in a variety of sizes as flat filters you can insert into stock air cleaner housings.
they also have the advantage of being washable and with proper care last "forever". i think these days there are even advanced hi flow dry elements that don't need oiling. i run one in my renault r s. my filter housing and cold air intake are all stock. you would not know its there. i think a fair few sizes are on offer these days from K + N and similar makers. given the 1.8 filter is also used on the 924 and several other cars there is probably a size that fits straight in/ i don't think the snorkel diam would be a problem. the shape is tapered to accelerate air flow and the inlet is positioned near the fan air stream. basically as close to a cold air intake as they needed to do back then. standard VWs did use the snorkel but had direct cold air intake ducting. i think the snorkel would not be restrictive. the air will just run faster in it with higher intake demand. the filter element iitself is the biggest restriction on air flow volume and velocity. |
| rfinegan |
Feb 23 2026, 04:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,186 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
| rfinegan |
| Geezer914 |
Feb 23 2026, 04:20 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,226 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
I eliminated my snorkel as I also installed a 50 mm throttle body. You can purchase a 50 mm air horn from eBay and trim back the snorkel to fit so not to restrict air flow. I blocked off the front of the air box where the snorkel attached and added a new opening at the rear of the box. Attached a hose and air horn as pictured.
| JamesJ |
Feb 23 2026, 08:29 PM
Member ![]() ![]() Group: Members Posts: 267 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
| 914werke |
Feb 23 2026, 10:18 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,555 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
(IMG:style_emoticons/default/agree.gif) I did this same thing I removed the OE snorkel found a preformed snorkel off a Junkyard motor that pointed the air PU back to the Drivers corner & made a couple brkts, (IMG:style_emoticons/default/aktion035.gif) |
| TRP |
Feb 23 2026, 10:41 PM
Thank you all for your replies. I will noodle on this a bit. I'm less worried about a cold air intake than just making sure the motor gets enough air to breath properly.
I appreciate all of the ideas. Much appreciated, Ted |
Lo-Fi Version | Time is now: 23rd February 2026 - 11:52 PM |
