| TonyA |
Feb 24 2026, 05:09 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 651 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
How can I set up a temporary oil pressure gauge and still have the idiot light work.
I think I would need to remove the oil pressure switch put in an adapter into the oil pressure port with a tee fitting for the gauge and the switch. What size fitting would i need to go into the case? Any suggestions on where i can buy? |
| brant |
Feb 24 2026, 05:20 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,148 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The case is 1.0 thread I believe by size 10
Also a grease gun takes what is essentially the same size. I believe it might be sae/American but it’s a size that is so similar to 10 x1.0 that it works and seals Be careful with (especially brass) hard fittings that will work hardened from vibration and crack eventually The hose is flexible and takes vibration The hard fittings vibrate and there is no flex to absorb the vibration What you ideally need is a dual pole sender switch that can riun both a gauge and light without trying to poorly engineer two switches in and add weight to a rigid design of plumbing VDO sells those dual pole senders. Just verify your sender specs before you buy |
| frank_c |
Feb 24 2026, 05:37 PM
Member ![]() ![]() Group: Members Posts: 69 Joined: 29-December 24 From: Austin, TX Member No.: 28,542 Region Association: None |
For the flexible hose, you can use a 928 brake line - it has the correct M10x1 fittings on both ends. You will need to use a copper seal with it. I have the dual-pole sensor, and replaced the 1/8" NPT brass extension that the PO installed with this brake line, which I was able to fully thread it into the case unlike the 1/8" NPT fitting.
https://www.pelicanparts.com/search/?q=928-355-080-04-M4 |
| bkrantz |
Feb 24 2026, 09:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,611 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I still don't like rubber lines in my pressurized oil plumbing system.
I do have the VDO dual sender, with pressure plus feed for idiot light. But I did have to get used to a lower PSI trigger for the light. |
| dtmehall |
Feb 24 2026, 09:50 PM
Member ![]() ![]() Group: Members Posts: 248 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
i guess the question that should be asked, is how temporary?
Lo-Fi Version | Time is now: 25th February 2026 - 05:37 PM |
