> Building another engine
post Feb 27 2026, 10:55 AM
Building another engine for future sale. This one is a 3.2 short stroke. Pauter cranks, canyon head studs, JE 10.5 pistons in Mahle 98mm cylinders. 964 oil pump. Cam for EFI. Twin plug heads with asco valve springs and retainers.
More to come.
Root_Werks
post Feb 27 2026, 02:55 PM
Village Idiot
Love to see engines getting built like this. Works of art!
Short stroke 3.2, would it wind up being less than a 3.2?
post Feb 27 2026, 03:56 PM
QUOTE(Root_Werks @ Feb 27 2026, 03:55 PM) *
It’s built on a 3.0 case with 98mm pistons and cylinders. Same cylinder as a 3.2 to 3.4 but the piston needs to be sized for a 3.0 rod. It’s a tried and true combo.
mlindner
post Mar 1 2026, 05:54 AM
Very nice Mark. Post more of the build, fun to see it come together.
post Mar 1 2026, 07:39 PM
Cleaning up the cam towers. Removed all the studs to replace with new. It also makes it much easier to clean the sealing surfaces. Removed the aluminum plugs and oil spray bars to install new. This greatly reduces the chance of debris obstructing oil flow. These parts are 45 years old…. A couple times in the ultrasonic and then blow everything off with compressed air.
post Mar 1 2026, 08:20 PM
(IMG:style_emoticons/default/smile.gif) Interesting, keep posting..
post Mar 5 2026, 02:44 PM
Mahle cylinders and custom JE pistons that have been undercrowned and coated.
Steve
post Mar 5 2026, 04:04 PM
Very nice!! What is the plans for cams and induction? Also always curious about cost?
infraredcalvin
post Mar 5 2026, 05:31 PM
Distracted Member
Ooooh, please lots of pics and details! Those JE’s look very similar in profile and piston cut to the Mahles that just went into my burnt 3.4.
What cylinders are those/where’d you source? I have some older Mahle motorsport 98mm single plug pistons i was thinking of doing a 3.2SS… but i need to source the cylinders or have the 3.0 cylinders bored and coated???
post Mar 5 2026, 06:49 PM
QUOTE(Steve @ Mar 5 2026, 05:04 PM) *
Cams are special. Streetable but very performance oriented. Induction will be Clewett ITB’s and Haltech efi. Cost is a core engine, parts and labor. The efi & itb’s add a significant cost over stock induction but really make it fun.
A note about EFI. There’s a cost for parts but you can expect to pretty much double the cost to actually get it running and tuned. We’ll have a custom harness made, engine installed in the car and dyno tuned.
I’ll post the engine to completion and then show it in the car if the buyer is ok with it.
post Mar 5 2026, 06:55 PM
Hard to tell from the pics but the pistons are undercut to save a bit of weight. Pauter rods are lighter and stronger than stock. It all adds up, or in this case, adds up to less weight.
flyer86d
post Mar 6 2026, 05:10 AM
I had a very similar motor in my track 911 way back when but with Weber 46’s and GE80 cams. It was a wonderful revvy engine that would light off the tires in first when it came up on its cams at 5000rpm, rev to 7500 and was very reliable. I never had it out of the car in the eight years I owned it. This will be a fun motor!
Charlie
post Mar 8 2026, 03:05 PM
Gonna be a rocket, keep posting as you go
post Mar 8 2026, 03:11 PM
Slowed down a bit while we finish a stock-ish 2.4 for a customer and work on some other stuff.
Also building an IROC car.
tailwind22
post Mar 9 2026, 11:56 AM
Super excited that the first 3.2 SS motor is destined for my 73 GT car. Going to have Mark throw some ITBs on it with a Haltech ECU. Will be a rocket! Love the work you guys are doing on the IROC.
post Mar 18 2026, 07:53 AM
More engine progress. This was after cc’ing heads, cutting piston rings, etc, etc.
Waiting on cams.
post Mar 20 2026, 08:04 PM
Not a glamour shot but progress.
My engine builder forgot that 914’s need the lover valve covers modified. We’ll do that eventually.
pete-stevers
post Mar 21 2026, 02:24 PM
Shinee Side Up Prep and Paint
THat motor looks great!! I bet it will sound as good as it looks!!!
post Apr 16 2026, 06:53 PM
Mocking up some parts.
Sorry, took the pick with the camera facing up.
- Lo-Fi Version Time is now: 17th April 2026 - 05:08 PM
