> Good fuel pump for 914-4 with twin Weber 34 carbs?
detective_snakes
post Mar 9 2026, 11:07 PM
So, since getting my car back "working", I've slowly whittled down the reason for the failing idle as the fuel pump being too strong. I'm pretty sure these carbs are supposed to take 3-4psi, and the mechanic installed a 6psi pump. Great. Amazing, even. Would explain why one of my carbs is backfiring, and the engine won't idle (unless I'm wrong and this is actually an acceptable pump solution?).
Does anyone have a recommendation for a solid pump I can use? At this point I'm past frustrated, just sort of annoyed I put my trust in a mechanic who screwed up constantly. Guess it's true, you want it done, you do it yourself.
This isn't a perfect rebuild or anything, so I'm not super interested in shelling big money for Bosch stuff, but if it's what I gotta buy I want to know so I can do things right.
And, thanks as always. You guys have helped me more than I could ever ask. If I ever see any of you, beers are on me.
post Mar 10 2026, 06:27 AM
Just PU a FP regulator. Id suggest the Holly.
mlindner
post Mar 10 2026, 07:10 AM
Pellican, 914 fuel pump, filter, hardware . 3.5 lbs max for carbs at $99. What I have with my 2.2 six with PMOs.....Work great. Mark
post Mar 10 2026, 07:42 AM
QUOTE(detective_snakes @ Mar 10 2026, 01:07 AM) *
Not necessarily.
Although high fuel pressure may cause excessive richness it sounds like you’re jumping to a conclusion that a fuel pump is going to solve your problems.
What evidence do you have that the carbs are excessively rich?
Have the carbs been balanced and synchronized? Are you sure your timing is set properly? Valves adjusted properly?
mmichalik
post Mar 10 2026, 08:30 AM
MikeM
https://www.cbperformance.com/product-p/319...z0J5nU8TsSzYuP5
This pump works great as well.
brant
post Mar 10 2026, 08:41 AM
most of the pumps for carbs will work.
but adding an adjustable regulator is a rock solid way of getting the pressure correct.
and allows you to use the pump you already have.
brant
post Mar 10 2026, 09:18 AM
Yes, fuel pressure regulator is necessary. I have found 2 1/2# is plenty, over pressurizing can be a problem
- Lo-Fi Version Time is now: 10th March 2026 - 09:47 PM
