> Billet pushrod tubes
StratPlayer
post Mar 11 2026, 01:59 PM
StratPlayer
68.00 a piece, are they worth it?
TRP
post Mar 11 2026, 02:17 PM
QUOTE(StratPlayer @ Mar 11 2026, 12:59 PM) *
$540.00 for pushrod tubes seems like quite the investment.
Tangerine has a set for $330.00, but they aren't billet, they are stainless.
What are you trying to solve for? Seems to me that the only benefit would be less resistant to damage/leaks in the tube itself. Most of the leaks come from the seals, not the tubes themselves.
'm having a 2.1 built right now and I did the evaluation based on cost/benefit and it was not worth it for me. I went with a set of high quality tubes and invested in the best seals/prep work.
More knowledgeable members will reply soon,
Ted
DC_neun_vierzehn
post Mar 11 2026, 04:19 PM
QUOTE(TRP @ Mar 11 2026, 02:17 PM) *
Ted
Which seals are now considered “the best seals these days”
TRP
post Mar 11 2026, 05:53 PM
I deferred to Ken Jansen, who is building my motor. He typically goes with OEM stuff, I would guess that's what he's going with. From what I've gathered here, the type IV tubes are. It as problematic as the type I tubes.
I'm still a new guy around here, someone else, more knowledgeable will be along soon. (IMG:style_emoticons/default/smile.gif)
post Mar 12 2026, 12:51 AM
@StratPlayer
date='Mar 11 2026, 12:59 PM' post='3248739']
[/quote]
No.
Was at Eurupean motorworks yesterday. He has them for $15 each.
Driver174
post Mar 12 2026, 03:51 AM
QUOTE(StratPlayer @ Mar 11 2026, 11:59 AM) *
They are expensive but work well. Along with Viton seals, they fit very snugly into mating bores. They are a bit of a pain to remove them without pulling heads off engine.
Tangerine Racing stainless tubes are pretty cool too but do not fit as tight into tube bores. These stainless tubes have a ring welded to them which make installation/removal of them very easy.
DRPHIL914
post Mar 12 2026, 01:37 PM
Dr. Phil
QUOTE(DC_neun_vierzehn @ Mar 11 2026, 05:19 PM) *
Ted
for me normally ive used the Viton seals working tthe best, anything else seems
to leak sooner. I just replaced some "factory" brand on the #1 tube last month with the viton- not sure why i did that last time around, might have been due to what was available or on hand, but i wont do that again.
for rear seal RMS that is last time i had to replace a leaking one it was VR Vitor Reitz and used a SABO from Brazille and that RMS is perfect after 2 -3 years so far.
post Mar 12 2026, 01:42 PM
QUOTE(TRP @ Mar 12 2026, 09:17 AM) *
Ted
IMO a good set of stock tubes with correct 'o'rings is hard to beat if they are fitted properly ? no sealant and just installed a good coating of motor oil and making sure the running surfaces for 'o' rings are smooth/clean and check retaining spring under the rocker gear in correct position.
- Lo-Fi Version Time is now: 15th April 2026 - 12:23 AM
