| friethmiller |
Mar 13 2026, 02:33 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,188 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
| 914Sixer |
Mar 13 2026, 06:30 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,433 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes 4 tabs (POT METAL). They may or may NOT break. Wedging small screw driver may get the job done.
| Spoke |
Mar 13 2026, 11:48 AM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,353 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
I don't mess with that connector. I would look for a newer housing versus trying to disassemble the connector.
Why are you trying to take it apart? |
| friethmiller |
Mar 13 2026, 01:23 PM
It was actually not as bad as I thought it would be. I pushed all four tabs outward and then used a small screw driver to pry up the cap just a little bit at a time going around the entire base. This took a bit of time/patience but it came off without incident. I wanted to remove it because there was a small screw lodged down below the contact points. This will make restoring these a lot easier now. Thanks for the suggestions/help.
Lo-Fi Version | Time is now: 13th March 2026 - 10:54 PM |
