Mar 14 2026, 11:35 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 731 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Just recently was "lucky" enough to find a set of main bearings to fit a -10/std/std crankshaft/case Type IV project. Already had a std/std/std set for another project (Kolbenschmidt brand from a WTB advertisement here in 914world.com).
However, most of the usual sources are currently out-of-stock of any brand main bearings. AAPistons.com has some silverline branded ones. Has anyone recently found any vendors with main bearings? If so, please share, so we all can know where to source main bearings. Thanks in advance. |
Mar 14 2026, 12:05 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,538 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I can get main bearings from our distributor but only .25 under. $180 shipped to your door. They don’t have many in stock.
Attached thumbnail(s) |
Mar 14 2026, 12:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,736 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
| JamesM |
Mar 14 2026, 01:17 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,184 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
From what I have heard the few people (builders) that have a supply of GOOD bearings are holding on to them for customer builds so the current options are paying someone to build you a motor, or not building a motor.
Mar 14 2026, 01:26 PM
From what I have heard the few people (builders) that have a supply of GOOD bearings are holding on to them for customer builds so the current options are paying someone to build you a motor, or not building a motor. We do that for 911 engine and trans parts. Not to control the market but just to make sure we have stuff on hand when we need it. You never know when the supply of a specific part will just dry up for a week or a month and pause a build. It cost thousands of dollars just to have inventory available and you certainly can’t stock everything but it is helpful to just start a build and resupply as needed. |
Lo-Fi Version | Time is now: 14th March 2026 - 01:31 PM |
