> Blinkers Failing but Relay Okay
HiroProtagonist
post Mar 15 2026, 03:00 PM
Hey all,
My blinkers are slowly failing, and I can hear the relay slowly click when I try to turn them on, but they don't actually flash and the lights on the dash don't respond. Hazards DO cause the lights to flash, but still no dash lights. Tested out a new solid state relay and it didn't fix it. It's both sides of the blinkers, so I don't think it's a bad ground at any of the corners, but maybe I'm wrong.
Would love any thoughts on what to check!
Spoke
post Mar 15 2026, 08:11 PM
Jerry
QUOTE(HiroProtagonist @ Mar 15 2026, 05:00 PM) *
Hey all,
It sounds like your flasher relay is failing.
Have the turnsignals worked normally before?
Is this behavior new?
What year is your 914?
Does your tach have separate L and R turnsignal indicators?
HiroProtagonist
post Mar 15 2026, 10:16 PM
QUOTE(Spoke @ Mar 15 2026, 07:11 PM) *
Behavior is new, turn signals did work before. The car is 1970, and the L/R indicators are not separate.
I thought the relay was failing as well, but we swapped in a new one (solid state) and it didn't work either!
Spoke
post Mar 17 2026, 05:46 AM
Jerry
QUOTE(HiroProtagonist @ Mar 16 2026, 12:16 AM) *
So the L/R indicators on a '70 flash together? That's a sign that the secondary coil in the flasher relay is weak.
Do you have a part number for the new solid state flasher relay? I wasn't aware of a solid state flasher relay. EP26 can be substituted for the 914 OEM flasher relay. EP26 is LED compatible if you go that way.
HiroProtagonist
post Mar 17 2026, 09:55 AM
QUOTE(Spoke @ Mar 17 2026, 04:46 AM) *
Awesome, I'll just order one of those! My mechanic had a relay he tested with that was new, but could be that something was awry with it. At this point I just need the blinkers to work and either way the relay seems like the first step to make sure it's good. Ordering one now!
Spoke
post Mar 17 2026, 10:00 AM
Jerry
QUOTE(HiroProtagonist @ Mar 17 2026, 11:55 AM) *
EP26 is manufactured w/o any connection to the C2 pin since it is used differently in some vehicles. It is easy to mod the C2 pin to allow it to work in your 914. I have instructions on my website on how to do the mod.
HiroProtagonist
post Mar 17 2026, 11:51 AM
QUOTE(Spoke @ Mar 17 2026, 09:00 AM) *
Heroic!! What does the C2 pin do?
Spoke
post Mar 17 2026, 01:14 PM
Jerry
The C2 pin (sometimes listed as K pin) was used by Porsche to alert the driver that an external turnsignal bulb was burned out. With normal bulbs, the C2/K pin would drive itself to VBAT when flashing.
If a light was burned out, C2/K pin would be open and both indicators would flash together alerting the driver to a burned bulb.
However over the years, the secondary relay would weaken and not close during normal operation. As soon as one adds LED turnsignals the entire alert system and operation Porsche designed falls apart. Thus EP26 is a good substitute. In EP26, C2/K is grounded internally so the L and R indicator never flash together.
EP26 can drive all incandescent bulbs if no LEDs are used for turnsignals.
HiroProtagonist
post Mar 17 2026, 02:27 PM
Awesome. I may actually have a turn signal bulb burned out as well, so I'll also swap to LEDs for those. Any idea what the bulb is for the signals, and if it needs to be a short one or something? I've ended up getting 1157 bulbs that are WAY too long before.
chmillman
post Mar 17 2026, 03:12 PM
Region Association: Europe
Anyone know or have a reference to a Euro/ROW relay that is the equivalent of an EP 26? I only see them listed on US sites…
Something like this maybe?
https://www.amazon.de/Yizhet-0-02A-20A-Moto...WF0aWM&th=1
Spoke
post Mar 17 2026, 03:47 PM
Jerry
QUOTE(chmillman @ Mar 17 2026, 05:12 PM) *
That flasher will work for vehicles with separate L and R indicators in the tach however the indicators need to be slightly rewired. Their common wire going back to the C2/K pin needs to be removed from each indicator and connected to the pigtail shown which is connected to the ground of the tach.
DRPHIL914
post Mar 18 2026, 07:02 AM
Dr. Phil
@Spoke
Hey Jerry, my gauge indicator is single, i have your side marker LED's in and i have LED bulb in the front signals so my dash indicator flashes once then stops, but the front and back indicators do flash , is the lack of dash flashing due to the relay not being a LED compatible?? if so do you sell the relays?
Phil
Spoke
post Mar 18 2026, 09:20 AM
Jerry
QUOTE(DRPHIL914 @ Mar 18 2026, 09:02 AM) *
@Spoke
Phil
@DRPHIL914
Yes the L/R indicator not flashing is a side effect of having LED turnsignals. I'm surprised it even flashes once. The OEM flasher relay senses the current in the turnsignal bulbs and if not 2 full incandescent bulbs as a load the L/R indicator will not flash alerting the driver that a bulb is burned out.
When LEDs are used for turnsignals, the OEM flasher relay does not drive the L/R indicator. EP26 modified can fix this. Yes I do resell modified EP26 for the later 914s with the L/R single indicator.
DRPHIL914
post Mar 18 2026, 09:42 AM
Dr. Phil
QUOTE(Spoke @ Mar 18 2026, 11:20 AM) *
@Spoke
Phil
@DRPHIL914
awesome i will get one from you !!
6 User(s) are reading this topic (6 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 18th March 2026 - 07:25 PM
