| 75ninefourteen |
Mar 16 2026, 01:16 PM
Newbie ![]() Group: Members Posts: 25 Joined: 3-October 25 From: Austin, TX Member No.: 29,016 Region Association: Southwest Region |
I've been trying to figure out what model this gauge was originally. So far in searching I've seen some close that are out of a 914-6, but have also seen similar marked as 911. Any ideas? I haven't had a chance to pull the gauge to look for a part number yet. I think the sensor for the oil temp is mismatched since it's reading cool.
Mar 16 2026, 01:41 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,540 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I am unable to assist with the gauge, but you may consider checking the low temp reading with a known source, IR or similar
| GregAmy |
Mar 16 2026, 02:10 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,647 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
That appears to be a 1970-1972 914/6 combo gauge, per P914.com (RIP)
https://web.archive.org/web/20190718110228/...auges_combo.htm If you tilt it back at an extreme angle you may be able to see a part number under the rim/bezel at the top. |
| brant |
Mar 16 2026, 03:36 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,160 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The gauge should have a tiny part number in it.
Seen at an angle Looks like the 6 one which doesn’t have dash bulbs The 4 cylinder combo gauge did have dash lighting |
| fixer34 |
Mar 16 2026, 03:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,400 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
The one on my -6 has horizontal lines in the two 'boxes'. See if you can get the part number on the upper rim.
| 914Wes |
Mar 16 2026, 04:09 PM
Member ![]() ![]() Group: Members Posts: 51 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
| 914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,435 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Look in 12 o'clock position. It is a 914-6 gauge with later 911 sportmatic temp style gauge.
| 75ninefourteen |
Mar 16 2026, 04:19 PM
| 75ninefourteen |
Mar 16 2026, 04:40 PM
| porschetub |
Mar 16 2026, 08:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,043 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
I am unable to assist with the gauge, but you may consider checking the low temp reading with a known source, IR or similar Thanks for the suggestion. I am planning to check the temp through the oil dipstick tube as a starting point. Good idea should be close enough as reading is from the sump anyway pay to check the "G" wire on the gauge to sender ,most likely you have a duff sender or wrong rating for the same ,cheers |
Lo-Fi Version | Time is now: 17th March 2026 - 03:06 AM |
