| TonyA |
Mar 19 2026, 06:49 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 661 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
My tach will not register over 2200 RPM even though it sounds like it revs way higher then 2200 the green wire is connected to the coil all grounds seem ok. Not sure what the problem is. Any suggestions.
| dtmehall |
Mar 19 2026, 06:53 PM
Member ![]() ![]() Group: Members Posts: 257 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
do you have access to another tach?
| mgphoto |
Mar 20 2026, 02:12 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,419 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
My tach will not register over 2200 RPM even though it sounds like it revs way higher then 2200 the green wire is connected to the coil all grounds seem ok. Not sure what the problem is. Any suggestions. You should be able to borrow a tech from your local auto parts, that should confirm what your revs should be. There may be a problem with a circuit in the tech. |
| rfinegan |
Mar 20 2026, 02:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,190 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
Bouncing needle and not responding to rev is very typical of a failing tach. Im told the capacitors break down and fail internaly. Are you running a points distibutor?
Lo-Fi Version | Time is now: 20th March 2026 - 08:27 AM |
