| brant |
Mar 22 2026, 08:07 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,211 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
a single 1.7 injector that was sent out/rebuilt... unfortunately i cant find the spec sheet
40$ + shipping Attached image(s)
| brant |
Mar 22 2026, 08:09 AM
1975 l-jet injectors
cores, used to run 10 years ago, stored dry 100+shipping Attached image(s)
| brant |
Mar 22 2026, 08:16 AM
L jet throttle body
no TPS very good core no wear edges from butterfly 50$ + shipping Attached image(s)
| brant |
Mar 22 2026, 08:23 AM
1.7 distributor with trigger points
was used as a travel spare for emergencies very low test miles on cap/rotor/points works well the vacuum canister diaphram holds vacuum on the port pointing outwards, not on the port pointing in 50$ plus shipping Attached image(s)
| brant |
Mar 22 2026, 08:27 AM
oil pump plate from cludes buggies (cb)
this is for a conversion to a full flow oil set up 10$ + shipping Attached image(s)
| brant |
Mar 22 2026, 08:31 AM
track exhaust made to fit the 2.0 bursche muffler
some of the bursche's have a removeable muffler at the flange just upstream it was an option this bolts there, maintains the cross-over of the system center outlet.. 3 bolts i used to drive to the track and bolt this on i have a spare flange if your bursche doesnt 20$ + shipping Attached image(s)
| brant |
Jun 8 2026, 10:47 AM
make me an offer... still need to clean this crate of parts off of the bench.
brant |
Lo-Fi Version | Time is now: 15th June 2026 - 03:08 AM |
