| DennisV |
Mar 25 2026, 07:47 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,019 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
If things go well next week, I might be able to take a run at installing the engine in our 914-6.
What should I do to prep for the marriage and / or a sequence of events should I follow to be most efficient? I’ve reviewed the Removing and Installing Engine section in the factory workshop manual. Any advice in addition, or contrary, to those steps? CURRENTLY * Engine is on a test stand * Transmission is on the floor * Chassis is on its wheels on a 4 post lift * Drive shafts are attached to the stub axle on the car * Wiring harness is on engine * Engine bay is pretty bare. No oil hoses, fuel hoses, fuel pump, engine wiring harness. ASSUMPTIONS Before Engine In Car * Mate transmission to engine * Remove air cleaner * Oil hoses routed in engine bay * Fuel lines installed * Fuel hoses routed in engine bay * Fuel pump mounted * Heat exchangers on engine (ideally, but…) * Engine bay rubber seals After Engine In Car * Drive shafts attached * Shift rod * Muffler * Hot air ducts, flaps * Air cleaner QUESTIONS * Will the ramps or cross-beams of the lift cause clearance or height issues? Below is a shot of the lift. * Will it be a problem to install the heat exchangers after the engine is in the car? They won’t clear to supports on the test stand. * Should I install the oil and fuel hoses in the engine bay first? * If I use the parts catalog listed length on hoses, will I be OK? Or will I wish I hadn't cut the hoses to length until the engine is in? Thank you. ![]() |
| VaccaRabite |
Mar 25 2026, 08:54 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,904 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Since your car is on a lift, put the engine and transmission on a motorcycle/transmission jack and lower the car on to the engine, using the transmission jack to do minute movements. The cross bar may interfere at the back of the 4 post lift. Or it may not. Hard to say given that photo.
Zach |
| DennisV |
Mar 25 2026, 09:08 AM
Since your car is on a lift, put the engine and transmission on a motorcycle/transmission jack and lower the car on to the engine, using the transmission jack to do minute movements. The cross bar may interfere at the back of the 4 post lift. Hi Zach, I have the Wilding Engineering 911 engine cradle adapter for a floor jack. Do floor jacks not normally raise high enough? Thus the need for a transmission jack? I have some room to roll the car forward on the ramps, if the rear cross bar is the main concern. I wasn't sure about the minimum clearance needed between the ramps. I will also be limited to how much I can lower the lift, based on the floor jack. Maybe that's a non issue if the floor jack can lift high enough. |
| mlindner |
Mar 25 2026, 09:26 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,798 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest
What six are you installing, or better yet what are you using for lower valve covers. If turbo fined style you will want to have them shaved so removal is possible for valve adjusting. Best, Mark
| DennisV |
Mar 25 2026, 09:32 AM
What six are you installing, or better yet what are you using for lower valve covers. If turbo fined style you will want to have them shaved so removal is possible for valve adjusting. I'm installing a factory 914-6 engine. I kept the original lower valve covers and sent them with the engine to the machine shop to make sure they were flat. I didn't use the turbo-style on the bottom, but thanks for the reminder on that. |
| Tom1394racing |
Mar 25 2026, 10:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 523 Joined: 25-August 07 From: CT Member No.: 8,039 Region Association: North East States
I did this recently and waited to install the CV/Axle assemblies after the engine was installed. Pretty tricky with the rear suspension and heat exchangers installed.
http://www.914world.com/bbs2/index.php?sho...=372298&hl= You might consider installing the CV/axles to the rear hubs before the engine goes in. |
| DennisV |
Mar 25 2026, 12:25 PM
I did the recently and waited to install the CV/Axle assemblies after the engine was installed. Pretty tricky with the rear suspension and heat exchangers installed. http://www.914world.com/bbs2/index.php?sho...=372298&hl= You might consider installing the CV/axles to the rear hubs before the engine goes in. Good thread. Thanks for sharing. CV/axles are already attached to rear hubs. Rear suspension is in. Heat exchangers are currently in a box. |
| brant |
Mar 25 2026, 01:44 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,254 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Did you drop the engine using the same lift?
I’ve seen (used) a 4 post lift that didn’t have enough clearance between the ramps once |
| DennisV |
Mar 25 2026, 01:49 PM
Did you drop the engine using the same lift? I’ve seen (used) a 4 post lift that didn’t have enough clearance between the ramps once The engine and transmission were already out of the car when I got it. So the factory manual guidance to "reverse the removal steps" for install doesn't help me much. (IMG:style_emoticons/default/biggrin.gif) |
| SKL1 |
Mar 25 2026, 02:06 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,819 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest
Looking at your lift, which is very similiar to mine, I think the clearance between the ramps will be very close or too narrow to "easily" mate the engine/transaxle to the car. I know for sure you can't with a 4 cylinder because of the cross bar mount.
That's why I wish I'd gotten a 2 post lift... but that's a story for another day. |
| rgalla9146 |
Mar 25 2026, 02:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,993 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
Denis can you move the car rearward so the crossbar on the lift is just below
the rear edge of the floorpan ? ... you'll gain an easier lift into the car. To be extra cautious attach a strap from the front suspension to the lift. Install the oil cooler hose to the cooler before installing engine. You'll have to tilt the right side of the engine upward to get the side tin past the rear inner trailing arm nuts. This is to avoid bending the tin and scratching the paint. Buy or borrow a 16" drift pin to guide the front engine mount toward the front chassis mount. Remove the halfshafts with stub axle attached. Install afterward into lowered trailing arms (detach at big lower coilover bolt) Use the drift pin to guide the stub axles back into the hubs. Don't roll the car without stub axles tightened in place. Tie, tape or strap all hoses wires and cables away from the engine opening. A lift table is very helpful. A floor jack is a challenge because the bigger mass a distance from where you are controling it. |
| mskala |
Mar 25 2026, 04:01 PM
R ![]() ![]() ![]() Group: Members Posts: 1,960 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
I have done the 4-post lift remove-install several times. I have a thread
somewhere about 20 years ago describing lift setup. Basically, it seems like all these lifts are slightly different spacing. For the future, yours is wide enough to make a couple mods, but not going to happen with the car already up. I have 42" between the lip of the rails when I have moved my one rail for this. The widest point is the front lip of the engine tin; as someone said, if this is not going to fit through, you will need to tip the engine a certain amount, then raise one side past the lip, then roll left or right, then get the other side by the other lip. It is not as bad as it sounds, as long as your engine is really supported well while tilted. My other worst issue with install/remove on the lift is the left side axle. I remove the wires to the reverse light switch, and then I think there is usually enough room to move eng/trans forward and back at the right times to swing the axle by the starter. |
Mar 25 2026, 05:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,798 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
I have been using a wood framed "table" on wheels for several years. This table also doubles for a work bench when not being used for engine removal/installation. raise the chassis with my HF scissors lift, roll the table with engine/trans under and lower the chassis onto the engine.
Will this be the first time installing into this chassis? |
| DennisV |
Mar 26 2026, 07:15 AM
I have been using a wood framed "table" on wheels for several years. This table also doubles for a work bench when not being used for engine removal/installation. raise the chassis with my HF scissors lift, roll the table with engine/trans under and lower the chassis onto the engine. Will this be the first time installing into this chassis? Yes. This is my first time installing any Porsche engine into a chassis. Also the first time mating the engine and transmission. So I guess before I put it in the car, I have a couple significant steps I need to sort out: 1. How do I support the engine and transmission while bolting them together? Do they just sit on the floor? Furniture dolly? Floor dolly? Do I bite the bullet and spend $200 on a hydraulic table cart? 2. Can the heat exchangers go on after the engine is in the car? If not, back to how do I support the engine while bolting them on. Can't be on my test stand. I know you folks have done this thousands of times, but I'm not finding the threads that are covering this part... |
| mskala |
Mar 26 2026, 07:40 AM
Yes, heat exchangers/muffler can go on after install.
At least when I was younger, the transmission, being only about 75 lbs, could be half lifted half pushed onto the studs pretty easily. |
| Cairo94507 |
Mar 26 2026, 09:36 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,744 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
We used one of the Harbor Freight lift tables and that really made it go smoothly. We installed engine and trans assembled. Easy to install transaxle when the engine is on the lift table. We did not have the heat exchangers on or the axles installed when we put the engine in. We did have to rock the engine to clear the suspension ear on the right if I recall correctly. But with the table it was an easy install. I still have my factory (original) engine mount and we used a long punch to line up the mount and then the bolt dropped right in place. After that was in we checked everything in the engine compartment for any conflicts and then installed the transaxle bolts. All in, took about 1/2 hour to get the engine bolted into the chassis. Good luck and enjoy the process. (IMG:style_emoticons/default/beerchug.gif)
Mar 26 2026, 09:49 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,874 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I think we have a total of about 7 HF lift tables. The 1K type. Invaluable in the shop. I have one at home I use all the time. Portable metal shop table, etc.
Mar 26 2026, 10:45 AM
A work table is a great asset, one that lifts is even better. When assembling the engine/trans I set them on a table/flat surface and shim the trans to get equal dimensions between the engine mounting surface and trans mounting surfaces. It takes a bot of jockeying to get the input shaft engaged, but slow and steady wins the race
| DennisV |
Jun 16 2026, 10:11 AM
Looking at your lift, which is very similiar to mine, I think the clearance between the ramps will be very close or too narrow to "easily" mate the engine/transaxle to the car. Now that I have the engine tin on it is clear the space between the ramps is too narrow. (IMG:style_emoticons/default/sad.gif) So I guess this leaves me with the @Gint cantilever method @rgalla9146 suggested or the floor jacks and jack stands "Pelican" method. They both seem precarious to me. In the jack stands scenario, I guess I am raising the engine to the car, rather than lowering the car onto the engine. I am hoping the Wilding Engineering 911 cradle will give the needed support and a 3/4 ton floor jack the height. Speaking with a couple folks, they suggested: * Take one side of the engine tin off. Does it matter which side? * Having the car nose down may make it hard to get the engine mount bolt installed. Is it worth the time / money to put wheel cribs under the front to reduce the angle? * Leave the starter on, but be mindful of clearance * Remove the engine cover * Carbs can stay on, but remove the air cleaner Any other 914-6 engine install tips that I will wish I knew in advance? |
| Cairo94507 |
Jun 16 2026, 10:20 AM
We installed my '95 3.6, complete in non-varioram intake, w/transaxle using a lift table. My car was on a scissor lift. We left the passenger side tin loose and had to slightly tip/rock the engine to one side to clear the suspension ears. With 2 people it was easy and went right into place. Then we used a long rod to center the engine mount (stock 6) and the bolt went right in. Installed the loose engine tin screws- kind of a pain but doable. Whole process, starting with donuts and coffee, took about 45 minutes. (IMG:style_emoticons/default/beerchug.gif)
Lo-Fi Version | Time is now: 23rd August 2026 - 04:42 PM |
