| potomacmidget |
Mar 25 2026, 09:35 AM
I gotta have more cowbell.... ![]() ![]() Group: Members Posts: 171 Joined: 27-March 11 From: Maryland Member No.: 12,860 Region Association: North East States
Hi All -
So...I decided to do a bit of a refresh on my 71 D-jet car. Adjusted the valves, new points, (same condenser) new cap, rotor and a rebuilt throttle valve switch. New vacuum hoses everywhere, functioning AAR . Had the car on 4X jackstands to adjust the valves, and was running the car and setting the idle - had it all back together (oil bath air cleaner, new hoses). Was running great. Lowered the car (removed all 4 jackstands) and now it won't start. Nothing has physically changed. I just pulled the fuel line post fuel filter and pre-fuel pump, and fuel flowed fine. Points gap looks good, I have cranked the car with the timing light on each spark plug wire, light flashes. I don't think air is an issue, AAR wide open and boot is off throttle valve. I DON"T seem to smell fuel with all the cranking. Did I lose the prime on my fuel pump? I have an original 3 port type installed, all new gas lines as of last March. Car was running great on jackstands, I am befuddled. Any advice appreciated! thanks, Reg |
| emerygt350 |
Mar 25 2026, 09:45 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,839 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
I would check the fuel pressure, not smelling some fuel with all that cranking...
| emerygt350 |
Mar 25 2026, 09:46 AM
You could try a shot of starter fluid too. If it starts you know you have a fuel issue. Then it is pressure or the trigger points/ecu. Did you double check to make sure the trigger point wires are making a good connection? |
| potomacmidget |
Mar 25 2026, 10:22 AM
I would check the fuel pressure, not smelling some fuel with all that cranking... You could try a shot of starter fluid too. If it starts you know you have a fuel issue. Then it is pressure or the trigger points/ecu. Did you double check to make sure the trigger point wires are making a good connection? Thanks! I will check the trigger points and get some starting fluid and report back. Thanks for your help, I appreciate it. |
| potomacmidget |
Nov 27 2026, 05:45 PM
All - after 8 months of abandonment I got motivated to solve the issue. I pulled the distributor and checked the points, reinstalled. Car fired up. I’m thinking that perhaps I previously pulled the distributor when piston 1 displayed what I thought was TDC compression stroke, but maybe it was the exhaust stroke? Maybe too many hours hanging my body in to see the timing marks and I got confused. Glad it’s running and idling well, but I found my newly installed (prior year) brake master cylinder is leaking. Ugh, that was like the worst job ever. So I guess I get to attack that project again. Regardless I appreciate all the help and information on this site. Just re-uped my subscription. Hope everyone had a great Thanksgiving.
| Front yard mechanic |
Nov 27 2026, 06:40 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,488 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Your car was just longing to get back on jack stands
Lo-Fi Version | Time is now: 28th November 2026 - 03:26 AM |
