| DennisV |
Mar 25 2026, 01:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 882 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Is there meant to be any tape or adhesive on the inside of the rear window?
When I removed the seat backs from the car, I noticed a thin line of black caulk like adhesive. It's on the inside and I can't tell what purpose it would serve. I scraped it off with a razor blade. I need to know if I need to replace it with something before reinstalling the seats. @Eric_Shea has a great install post, but I don't see any mention of butyl tape on the interior side of the glass. Thanks. |
| 914werke |
Mar 25 2026, 02:04 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,602 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
What Ive seen on the lower edge of the glass is a tape line. Also what is most often missing are small swatchs of vinyl to trim out the cavity where the belt goes behind the backpad.
| friethmiller |
Mar 25 2026, 02:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,202 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
I believe the factory installed a strip of black tape across the rear window so the paint color wouldn't show through. I installed a strip of electrical tape on my red '74 after the glass install to mimic this.
| wonkipop |
Mar 25 2026, 02:51 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,471 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
What Ive seen on the lower edge of the glass is a tape line. Also what is most often missing are small swatchs of vinyl to trim out the cavity where the belt goes behind the backpad. i've got a clear memory of re-installing the rear glass in my 914 some 25+ years ago after it came loose and rattled. the factory used black tape across the lower edge of the window on the interior. this covered visible mastic on the other side of the glass. for cosmetic purposes. the small pieces of vinyl you mention at either end had the upper edges covered by the tape. i used electrical tape for the reinstallation. i replaced the electrical tape strip about 5 years ago when i was recommissioning. what @DennisV can see on his glass is the trace left of the original factory tape. i dont know what tape the factory originally used but it was black. even on a brown interior like my car the tape was black. |
| DennisV |
Mar 25 2026, 04:57 PM
I believe the factory installed a strip of black tape across the rear window so the paint color wouldn't show through. I installed a strip of electrical tape on my red '74 after the glass install to mimic this. Ah. OK. This makes sense. @wonkipop Thanks for the color note. Our interior is also brown. Thank you all. |
| DennisV |
Mar 27 2026, 09:17 AM
i replaced the electrical tape strip about 5 years ago when i was recommissioning. Thinking about executing this. In my experience when electrical tape gets hot it turns gooey and starts detaching. So off to the inter webs to research if I'm just not buying the right type / brand. Usually whatever Ace has. It looks like Scotch Super 33+ is a popular option. In heat tests Project Farm showed Duck Professional performed best. Any particular brands you've used that had good longevity for this purpose? |
Lo-Fi Version | Time is now: 27th March 2026 - 10:56 AM |
