| Literati914 |
Mar 31 2026, 03:21 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,235 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
Which gaskets are needed for the area @ the runners and the head, on a 1.7L w/ single carb ?
There was 8 individual metal gaskets when I removed the runners (single carb). Those may be correct I don't know, but they'll need to be replaced - I see generic type 4 gaskets in single (large) paper gaskets and these single metal ones. Does one type tend to be better than the other? - both are not needed I presume? I'm gonna put the single carb back on for a while then move to dual 40idf after a couple months probably. Which are best for that set up, if different? |
| porschetub |
Mar 31 2026, 11:13 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Which gaskets are needed for the area @ the runners and the head, on a 1.7L w/ single carb ? There was 8 individual metal gaskets when I removed the runners (single carb). Those may be correct I don't know, but they'll need to be replaced - I see generic type 4 gaskets in single (large) paper gaskets and these single metal ones. Does one type tend to be better than the other? - both are not needed I presume? I'm gonna put the single carb back on for a while then move to dual 40idf after a couple months probably. Which are best for that set up, if different? Those alloy gaskets are from the T4 carbed bus engines ,they are fine but one use only as they are crush gaskets ,cheers. |
Lo-Fi Version | Time is now: 1st April 2026 - 12:03 AM |
