| orangecrate |
Apr 5 2026, 04:12 PM
Member ![]() ![]() Group: Members Posts: 182 Joined: 16-September 13 From: Apache Junction AZ Member No.: 16,394 Region Association: Southwest Region |
Who among you are running a straight mechanical oil pressure gauge and what do you use for oil line? How is it mounted? Looking for ideas. thanks
| mjrrti |
Apr 5 2026, 04:47 PM
High Desert Member ![]() ![]() Group: Members Posts: 61 Joined: 4-February 14 From: Apple Valley, Ca Member No.: 16,959 Region Association: Southern California |
Who among you are running a straight mechanical oil pressure gauge and what do you use for oil line? How is it mounted? Looking for ideas. thanks I have a mechanical oil gauge in my car mounted in the center console. My car is a Subaru conversion but that doesn’t really affect the gauge. I originally ran plastic line that came with the gauge down the center tunnel. That was until some stinkin’ rodent chewed it in two. Now it is 1/8” copper and no problems since. I like the accuracy of the mechanical gauge. |
Apr 5 2026, 05:24 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,604 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I once used one to check oil pressure until I hooked up the dash gauge. Off the rack gauge from flaps and a hose from a grease gun.
Apr 7 2026, 08:12 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,577 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
maybe an old guy thing, I like having an oil pressure a (1/8") copper tube fed and oil temperature (capillary tube) gauges. I found a couple small 1 1/2" diameter gauges, mount them on the passengers side of the tunnel. work well
| Chad911sc |
Apr 7 2026, 12:07 PM
Member ![]() ![]() Group: Members Posts: 304 Joined: 24-September 24 From: Florida Member No.: 28,374 Region Association: South East States |
Just got my engine back in. I have a permanent gauge in the engine compartment that is ran off of a tee from the electrical gauge sender. It’s nice having the mechanical reference because my electrical gauge showed about 12 pounds of hot idle pressure, but the mechanical gauge read 18lbs.
Attached thumbnail(s) |
| orangecrate |
Apr 7 2026, 12:25 PM
Just got my engine back in. I have a permanent gauge in the engine compartment that is ran off of a tee from the electrical gauge sender. It’s nice having the mechanical reference because my electrical gauge showed about 12 pounds of hot idle pressure, but the mechanical gauge read 18lbs. |
| Chad911sc |
Apr 7 2026, 12:39 PM
Factory color…Olympic Blue
| Geezer914 |
Apr 7 2026, 04:03 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,270 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
Ran a 3an line to a T fitting to keep the idiot light sender and ran a 3an line from the to the gauge in the center console. (IMG:style_emoticons/default/welcome.png)
Lo-Fi Version | Time is now: 8th April 2026 - 02:49 AM |
