> Amco Shift Knob Set Screw, Drilling and tapping a new hole?
FlacaProductions
post Apr 7 2026, 07:03 AM
Greetings,
The set screw hole on the bottom collar of my Amco shift knob has cracked and needs to be re-drilled and tapped.
Picture is not mine but accurately illustrates the issue although this set screw seems much larger than mine.
I have filled the hole/crack with JB weld and the whole collar is solid.
What's my best approach to re-drill and tap?
Go thru the JB at the (approximate) same point or pick a new point of entry?
I have the original screw but haven't figured out the size/thread just yet.
Thanks!
Brian
Beach914
post Apr 7 2026, 11:55 AM
I have one with the same problem. will probably drill and tap in 180 degree location after filling and blending the damaged hole with jb weld.
- Lo-Fi Version Time is now: 8th April 2026 - 12:32 AM
