| thomasotten |
Apr 8 2026, 09:43 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,572 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 |
Microsquirt ECU for sale. It has a connection problem. One of the fuel injection circuits will sometimes cut out (pin 9 and 10). The problem, once identified, was resolved by simply pushing the harness in firmly. However, the problem returned. Always, it could be resolved with the simple harness push. I believe it is a bad connection, not in the harness but in the ECU (replacing the ECU solved the problem).
I have tested the pins for continuity to the backside where the soldering is, but can't find any problems. Will requires someone with patience and necessary troubleshooting and soldering skills. Or, if someone know what the likely issue is, please reply here as well. Offering as-is. $45 shipped. Attached thumbnail(s) |
| 914Wes |
Apr 8 2026, 04:24 PM
Member ![]() ![]() Group: Members Posts: 52 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
Ill resolder it for you for free if you want to see if that solves the issue.
Apr 8 2026, 10:10 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,771 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
I’ll take it. PM incoming for payment details
Lo-Fi Version | Time is now: 9th April 2026 - 05:18 AM |
