| 914Wes |
Apr 11 2026, 07:11 PM
Member ![]() ![]() Group: Members Posts: 54 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
I have seen this online before but could not find the link so here is my copy rescanned. Contains some useful sway bar info:
h_and_h_914_sway_bar_instrutions.pdf ( 1.13mb )
Number of downloads: 5 |
| sixnotfour |
Apr 11 2026, 08:55 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,198 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
(IMG:style_emoticons/default/beerchug.gif) Nice ,,I just found an 18mm front in my pile yesterday.... (IMG:style_emoticons/default/beer.gif)
| bdstone914 |
Apr 11 2026, 09:42 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,288 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
What is find useful are the formulas to calculate the twisting force.
This helps to know the affect of the change when you have adjustable levers. I am still working on making 16mm sway bars with adjustable levers to be able to have an effective range of a 15 to 19 mm bar. We also have a bunch of sway bars ranging from 15 to 22mm with adjustable levers and Heim joint drop links. Bars, levers are restored. Working on restoring drop links and assembling with correct hardware. |
| seanpaulmc |
Apr 12 2026, 05:48 AM
Member ![]() ![]() Group: Members Posts: 443 Joined: 6-December 16 From: Orlando, FL Member No.: 20,649 Region Association: South East States
What is find useful are the formulas to calculate the twisting force. This helps to know the affect of the change when you have adjustable levers. I am still working on making 16mm sway bars with adjustable levers to be able to have an effective range of a 15 to 19 mm bar. We also have a bunch of sway bars ranging from 15 to 22mm with adjustable levers and Heim joint drop links. Bars, levers are restored. Working on restoring drop links and assembling with correct hardware. Bruce, Do you have bushings for these H&H drop links? |
Apr 12 2026, 05:53 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,620 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
What is find useful are the formulas to calculate the twisting force. This helps to know the affect of the change when you have adjustable levers. I am still working on making 16mm sway bars with adjustable levers to be able to have an effective range of a 15 to 19 mm bar. We also have a bunch of sway bars ranging from 15 to 22mm with adjustable levers and Heim joint drop links. Bars, levers are restored. Working on restoring drop links and assembling with correct hardware. Bruce, Do you have bushings for these H&H drop links? I have an h&h bar that needed bushings. Another member here made me up a set on his lathe. I think it’s pretty easy. |
| mate914 |
Apr 12 2026, 07:19 AM
Matt ![]() ![]() ![]() Group: Members Posts: 935 Joined: 27-February 09 From: Eagles mere, PA Member No.: 10,102 Region Association: North East States
Number of downloads: 5PDF file does not show the rear sway bar. Somewhere I have the info on paper, but PDF would be great also. Matt |
| bdstone914 |
Apr 12 2026, 07:45 AM
Number of downloads: 5PDF file does not show the rear sway bar. Somewhere I have the info on paper, but PDF would be great also. Matt That is all we had. The rear bar installation is pretty straight forward. We have both fron and rear H & R bars and can show assembly when we get there. |
Lo-Fi Version | Time is now: 12th April 2026 - 09:06 AM |
