> Bouncing tach and speedo, where to start
hndyhrr
post Apr 16 2026, 07:38 PM
Last time i drove the pumpkin got almost home and had the fuel pump and master cylinder go side ways on me.
New MC is installed and brakes bled.
new fuel pump and gas tank going in this weekend.
During that drive I noticed that the tach and the speedo were bouncing alot. The speedo milage has never worked but the trip milage did.
Could this be a ground issue?
WCR is coming up and need to have it all taken care of.
Thanks guys
Renee
barefoot
post Apr 17 2026, 06:42 AM
Speedo is not electric, look for a twisted speedo cable back at the tranny.
My speedo angle drive on the tranny had got loose & rotated so the cable got kinked.
had to get new speedo drive gear sequently.
OR if you're just lucky just lube the cable from the speedo end. (IMG:style_emoticons/default/smile.gif)
Barefoot
post Apr 17 2026, 04:26 PM
QUOTE(hndyhrr @ Apr 17 2026, 01:38 PM) *
Thanks guys
Renee
A bouncing tacho can be wiring issue from the engine bay (coil ) to gauge ,bad earth etc or the gauge itself is failing and has lost its stability which means there is a fault in the 50yr old driverboard .
Speedo will be a bad cable or broken/misaligned drive cog/s ,cheers.
2 Members: dtmehall, hndyhrr
- Lo-Fi Version Time is now: 17th April 2026 - 05:07 PM
