| Tdskip |
Apr 24 2026, 09:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,757 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Hi - happy Friday all.
I pulled the professionally rebuild but incorrectly assembled (ugh!) gearbox to install one that Dr Evil rebuilt (yah!). I need to swap the whole assembly as a unit (#10 and all the attached parts) over which would be the first time I'm doing that so it seemed prudent to ask for some coaching to make sure I do it properly. Best to do prior to installing the Dr Evil rebuilt box or can it be done as easily once that is installed on the car? Any tips on making sure I get the alignment correct? Thanks! |
| Shivers |
Apr 24 2026, 09:57 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,363 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
Hi - happy Friday all. I pulled the professionally rebuild but incorrectly assembled (ugh!) gearbox to install one that Dr Evil rebuilt (yah!). I need to swap the whole assembly as a unit (#10 and all the attached parts) over which would be the first time I'm doing that so it seemed prudent to ask for some coaching to make sure I do it properly. Best to do prior to installing the Dr Evil rebuilt box or can it be done as easily once that is installed on the car? Any tips on making sure I get the alignment correct? Thanks! I'd replace #20, out of the car is good. Shift it into neutral. There are two nuts that hold it in. Remove those and I just wiggled mine out. It will all stay together except maybe #20. |
| Tdskip |
Apr 24 2026, 10:12 AM
| TRP |
Apr 24 2026, 10:29 AM
Member ![]() ![]() Group: Members Posts: 322 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Oh man, this is very timely! I have to swap that same part (parts?) out from one trans to anther today. One is modified for the CF Racing shift linkage and the other isn't. I don't want to retain the Tangerine linkage and not have to rework two of them.
Thank you! Ted |
| TRP |
Apr 24 2026, 12:43 PM
Oh man, this is very timely! I have to swap that same part (parts?) out from one trans to anther today. One is modified for the CF Racing shift linkage and the other isn't. I don't want to retain the Tangerine linkage and not have to rework two of them. Thank you! Ted All done! Man... why does gear oil smell so horrible? (IMG:style_emoticons/default/barf.gif) Smells like 5 years of body odor and regret. |
Lo-Fi Version | Time is now: 24th April 2026 - 02:00 PM |
