> Charging Issue?, I'm terrible at solving electrical problems
sdoolin
post Apr 25 2026, 11:05 AM
Voltmeter shows between 10V - 12V at idle (and everywhere else). Voltmeter drops to 10V when headlights, flashers, and wipers switched on. Multimeter across the battery terminals at idle reads 12.5V.
Alternator was verified good several years back when I built this engine.
I'm not sure what to check next?
mgphoto
post Apr 25 2026, 11:30 AM
QUOTE(sdoolin @ Apr 25 2026, 09:05 AM) *
Isolate the battery and check voltage. If you charge the battery till it is full, see how long it takes for the voltage to drop without a load, that will tell you the condition of the battery.
sdoolin
post Apr 25 2026, 11:56 AM
OK, so I checked some more things, and I am NOT GOOD with a multimeter. But, here's what I found (all measurements at idle):
Battery = 12.5V
Green Wire from alternator and chassis ground = 4.5V
Brown wire from alternator and chassis ground = 0.05V (essentially 0)
Red wire from alternator and chassis ground = 13.8V
mgphoto
post Apr 25 2026, 02:58 PM
13.8 your alternator looks to be ok but your battery might be dead, look up minimum voltage and full charge for the battery you are using. This measurement is made with the engine off.
fixer34
post Apr 25 2026, 03:35 PM
QUOTE(sdoolin @ Apr 25 2026, 12:56 PM) *
Battery = 12.5V
Assume red wire to chassis ground reading is being made at the battery positive terminal while the engine is running? Do the same measurement across the actual battery terminals. Voltage reading should be the same, or very close.
If it isn't, check/clean the battery terminal connections, the red wire connection to the positive post, the ground strap from battery to chassis, and the chassis strap underneath to the transmission. Unbolt and make sure the connections are clean/shiny.
sdoolin
post Apr 25 2026, 04:13 PM
Battery is virtually new, and lives on a trickle charger when not being driven. Terminals clean and tidy. All grounds clean and tidy and nice and tight.
Red wire measurement is between the wire/terminal and the chassis ground that lives next to the relay board.
mgphoto
post Apr 25 2026, 06:25 PM
QUOTE(sdoolin @ Apr 25 2026, 02:13 PM) *
So what is the voltage, after sitting on the trickle charger and then after sitting all night without the charger?
post Apr 25 2026, 06:31 PM
Is the voltage in the 13.5 - 15v when running?
If not I would pull the alternator for a bench test at your local starter/alternator rebuilder
- Lo-Fi Version Time is now: 25th April 2026 - 07:26 PM
