| ILM914 |
Apr 27 2026, 03:41 PM
Member ![]() ![]() Group: Members Posts: 105 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi all, Please help with this if you can. it seems I have not found a clear answer on this question. I have a 73 914 2.0. If I go out in the morning before I run the car the oil level reads about half an inch above the high/full mark. If I start/run the car then shut it off ; wait 4-5 min then check it its right on the high mark. So the Question is which method is correct? in the am after car has sat for hours or after start up then shut off and wait 4-5 min? Thank you 914 people - much appreciated, Joe
| Spoke |
Apr 27 2026, 04:12 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,379 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Sounds like you're ok. As long as the level is not too high you should be ok.
It would make sense that after running the oil level is a little lower since oil is everywhere in the engine and not in the pan. |
Lo-Fi Version | Time is now: 27th April 2026 - 06:32 PM |
