> back up light connection at the switch in the transmission, how to reattach
DRPHIL914
post Apr 29 2026, 08:44 AM
Dr. Phil
When I removed the harness when pulling the motor I pulled one of the wires out of the small round end that the 2 wires use to push into the back up light switch, so the question is how do I put that wire back into the ball like end ? I tried using a crimper but it is out of shape and cant get pushed into the socket. im sure there is probably a special crimper to use that type of connector ?
Philip
Luke M
post Apr 29 2026, 09:00 AM
QUOTE(DRPHIL914 @ Apr 29 2026, 07:44 AM) *
Philip
Sounds like the terminal has pulled out of the wire correct? If so then strip the wire back and solder it together. Pretty sure these are soldered from the factory.
DRPHIL914
post Apr 29 2026, 09:06 AM
Dr. Phil
QUOTE(Luke M @ Apr 29 2026, 11:00 AM) *
Philip
Luke,
Yes, it pulled out of the connector. Yes i can solder that back in there, should have done that with it out of the car lol but i can do that .
Thanks for the suggestion
mgphoto
post Apr 29 2026, 09:08 AM
QUOTE(DRPHIL914 @ Apr 29 2026, 06:44 AM) *
Philip
Large blob of solder on the tip of the wire, a little shaping and push into place.
post Apr 29 2026, 10:51 AM
Be sure the pin is there… (IMG:style_emoticons/default/smile.gif)
post Apr 29 2026, 11:01 AM
QUOTE(Luke M @ Apr 29 2026, 09:00 AM) *
Philip
AFAIK the "barrel ends" are available at Flaps
- Lo-Fi Version Time is now: 29th April 2026 - 12:15 PM
