> WTB: Vent Hoses for Fuel Vapor @ Canister and @ Engine Compartment, NOT the plastic ones @ rocker panels
Literati914
post Apr 29 2026, 07:40 PM
I've got a '73 that I'm wanting to replace the fuel venting system on.. though I think all early cars had the same set up. They are braided and probably close to 1/2" or so ID. (I could probably use the thin ones too, to and from the expansion tank)
I need the ones up front that connect to the charcoal canister as well as the ones that connect to the air cleaner box and the fan housing. This is a 1.7L if that matters.
If someone's parting out an early car and have these, let me know. Or if someone's got a good source to recommend, that would be great too.
Replies(1 - 1)
post Apr 30 2026, 11:42 AM
So you Want the OE plastic lines that run from F to R of the car along the drivers rocker or you want the short ones (same material) that go from wheel well to tank mounted charcoal can?
3 User(s) are reading this topic (2 Guests and 1 Anonymous Users)
- Lo-Fi Version Time is now: 30th April 2026 - 12:39 PM
