| Mike1981 |
May 2 2026, 11:11 AM
Member ![]() ![]() Group: Members Posts: 269 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
Hello Everyone,
Well, I'm finally retired and am able to work on my 914. I started a post about my turn signals and have time to do it. I currently have this board. Symptoms: Turn signals will turn on solid if the turn signal stalk is up or down on the column. Also tested and have 12 DC at each corner front and rear turn signals.... Just noticed my Hazard lights do not work. Do you feel the square/silver relay in this pic would control both turn and hazard lights? If so, is there a replacement? |
| mgphoto |
May 2 2026, 11:16 AM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,464 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Hello Everyone, Well, I'm finally retired and am able to work on my 914. I started a post about my turn signals and have time to do it. I currently have this board. Symptoms: Turn signals will turn on solid if the turn signal stalk is up or down on the column. Also tested and have 12 DC at each corner front and rear turn signals.... Just noticed my Hazard lights do not work. Do you feel the square/silver relay in this pic would control both turn and hazard lights? If so, is there a replacement? The silver square is the high beams, the turn signal relay is round and under the dash. The turn signal will light up solid if the key is off, actually a german safety feature. |
| Mike1981 |
May 2 2026, 11:32 AM
Thanks
Please help me understand where the turn signal relay would be located the turn signal relay is round and under the dash QUOTE he turn signal relay is round and under the dash |
| L-Jet914 |
May 2 2026, 12:57 PM
Member ![]() ![]() Group: Members Posts: 392 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
Thanks Please help me understand where the turn signal relay would be located the turn signal relay is round and under the dash QUOTE he turn signal relay is round and under the dash (IMG:http://bowlsby.net/914/Classic/zTN_Elect_Relays_MainFusepanel.jpg) Here is the layout of the under dash fuse panel. The turn signal relay is the large rectangular relay #3. PN: 91461830311 Unless Porsche changed the layout after 71 which others may chime in on. |
| Spoke |
May 2 2026, 01:14 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,381 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Doesn't look like your flasher relay is on your relay board. As mentioned the relay itself is usually a square black plastic bodied relay. Here's a couple of pictures of the relay and its connector. The connector has flat spades as the relays have round pins.
| Mike1981 |
May 2 2026, 02:18 PM
Thanks for these suggestions.
I believe my board is different than the ones sent by the replies. I guess ill keep looking but cannot find the relay is my biggest issue... |
Lo-Fi Version | Time is now: 2nd May 2026 - 07:20 PM |
