| Kansas 914 |
May 8 2026, 07:25 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,008 Joined: 1-March 03 From: Durango, Colorado Member No.: 373 Region Association: Rocky Mountains
I have conflicting information on the correct oil filter in my 914/6 conversion.
It is a 1975 with a 1976 2.7L CIS. It does have a 914/6 Oil tank. I have been told Mahle OC54 and OC61. I have both on the shelf which confuses me more. Thanks in advance - Mike |
| DennisV |
May 8 2026, 08:49 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 915 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I have conflicting information on the correct oil filter in my 914/6 conversion. It is a 1975 with a 1976 2.7L CIS. It does have a 914/6 Oil tank. I have been told Mahle OC54 and OC61. I have both on the shelf which confuses me more. Thanks in advance - Mike Isn't the correct filter dictated by which oil filter console (aka bracket or standoff) you have? Stock 914-6 oil tank has 901-107-025-00 console, that would fit 901-107-203-09 filter. This is same as used on 1965-73 911s. Not sure which Mahle that would map to. |
| smg914 |
May 8 2026, 09:44 AM
Sahara Beige Steve ![]() ![]() ![]() Group: Members Posts: 1,988 Joined: 22-February 04 From: Tampa, FL Member No.: 1,695 Region Association: None |
From what I understand either of those filters OC54 or OC61 will work on a stock 914-6. I use the red Purolator PC 34 (901.107.203.10) sold by Porsche Classic
| aturboman |
May 8 2026, 09:58 AM
Member ![]() ![]() Group: Members Posts: 156 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
This is correct data. Here is a original 6 with the factory Purolator filter referenced. The car is running a 3.2. The stock oil tank dictates the filter needed. Recommendation is to use only Porsche filters, they have an internal bypass many aftermarkets do not.
From what I understand either of those filters OC54 or OC61 will work on a stock 914-6. I use the red Purolator PC 34 (901.107.203.10) sold by Porsche Classic |
| Root_Werks |
May 8 2026, 10:39 AM
Village Idiot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,973 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest
Also have a 2.7 with stock 914-6 tank. Believe I run the OC61.
| sixnotfour |
May 8 2026, 11:11 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,231 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
depends on factory adapter ,,stock oc=61 ... there is a 911 , adapter that fits stock tanks and Bens, uses OC-54 .... thread size determines wich one..
| mskala |
May 8 2026, 12:54 PM
R ![]() ![]() ![]() Group: Members Posts: 1,945 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
For stock console, OC-61 is the right one. Lately, I've been pushed to OC-59
by (I think) pelican. Maybe OC-61 is discontinued. |
| Kansas 914 |
May 8 2026, 03:09 PM
Thanks guys - you are the best - cheers!
| mb911 |
May 8 2026, 04:04 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,762 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest
A bunch of misinformation here. The correct filter for a stock console is oc61 and for the upgraded console like what I sell should use the oc54. It has zero to do with oil lines (IMG:style_emoticons/default/wacko.gif) it’s all about the console
| rick 918-S |
May 8 2026, 05:13 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,263 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I have absolutely nothing to contribute to this discussion. Just wanted to say Hey! (IMG:style_emoticons/default/bye1.gif)
| sixnotfour |
May 8 2026, 05:42 PM
oil lines ??
Filter thread size yes.., 0C-61 smaller 0C-54 bigger |
Lo-Fi Version | Time is now: 8th May 2026 - 06:18 PM |
