| Mike Fitton |
Jun 3 2026, 01:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 633 Joined: 13-May 11 From: Mount Prospect, IL Member No.: 13,069 Region Association: Upper MidWest
| wonkipop |
Jun 3 2026, 05:45 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,532 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
i can go down and measure mine a bit later.
but bumper is on car so won't be able to give you hole diams. but can certainly get you set out dimensions to out side tit dimensions. if you have the tits you can work out where the bolts are located using those. |
| wonkipop |
Jun 3 2026, 06:52 PM
| sixnotfour |
Jun 3 2026, 07:59 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,263 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Are you adding them to the bumper pictured ??
Early sharp corner license plate area.. Bumper , no tits allowed |
Lo-Fi Version | Time is now: 4th June 2026 - 12:52 AM |
