> Starter - Replace 6v with 12v, Wanting to go to 12v - Starter Compatible?
hot air
post Jun 4 2026, 04:38 PM
Are the shafts same OD? Do I need a different bushing?
Help!
Conrad
post Jun 4 2026, 07:30 PM
914’s have always had a 12v starter and entire electrical system is 12v (IMG:style_emoticons/default/shades.gif)
post Jun 4 2026, 09:33 PM
QUOTE(hot air @ Jun 4 2026, 03:38 PM) *
Help!
Conrad
What exactly are yiuvtrying to compare? Early VWs and 356 had 6 volt systems.
Do you have a 914. All were 12 volt
JamesM
post Jun 4 2026, 10:18 PM
QUOTE(Superhawk996 @ Jun 4 2026, 05:30 PM) *
I believe all type 4 applications (not just 914s) were 12v as well.
You mentioned a bushing, 914s starters don't use the shaft end bushing.
Are you working with a VW/bus/Vanagon trans?
Need a lot more information here.
post Jun 5 2026, 12:16 AM
If you’re asking about a VW beetle, the 6 volt versus the 12 volt starters had a different number of teeth on the gears. They also had different flywheels with different teeth patterns.
But, yes IIRC there is a conversion bushing you will need, in addition to a different starter, battery, flywheel, alternator/generator, wiper motors, etc.
1 Members: Franz_x
- Lo-Fi Version Time is now: 5th June 2026 - 02:58 AM
