| Mike1981 |
Jun 10 2026, 10:30 AM
Member ![]() ![]() Group: Members Posts: 284 Joined: 21-July 14 From: Phoenix Member No.: 17,663 Region Association: South East States |
Hello Everyone
Work on the suby conversion continues.... I've had many help me in the recent past. Hope to ask for additional help.(Thanks) I have these coilovers on the rear of the car. https://cart.bilsteinus.com/shock-24-001793.html The drives side is almost 2" lower than the passenger side. Both are on the 6th or top adjustment with the circlip installed. Could this be a coil issue or a shock issue? Any Ideas as to how to adjust these??? ill add pics tonight.... Thanks Mike |
Jun 10 2026, 11:38 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,762 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Coils can lose their spring over time. Sometimes unequally. Might be time for a new set.
| Mike1981 |
Jun 10 2026, 04:12 PM
Thanks Mepstein
Do you feel it's the coils or the shocks? Or both?? |
| porschetub |
Jun 10 2026, 10:39 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,119 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
| infraredcalvin |
Jun 10 2026, 11:38 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,753 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
Time to get some adjustable coil-over sleeves, cheap and springs plentiful!
| Dave_Darling |
Jun 11 2026, 01:48 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,344 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
These are adjustable. They are coil-overs, the coil is over the strut. Changing the position of the spring perch just hides the problem.
The springs have likely sagged or broken. Almost certainly time for new springs. --DD |
| wonkipop |
Jun 11 2026, 04:11 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,550 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
there is a chance it could also be the adjustment of the front torsion bars.
a high right side front or weak left side front will transfer and cause the left side rear to be down. thats not to discount a weak rear spring. but just saying. |
Jun 11 2026, 04:47 AM
Thanks Mepstein Do you feel it's the coils or the shocks? Or both?? The springs hold up the car. The shocks control compression and rebound. Once you remove the assembly from the car, you can remove the springs from the shock body and "test" the shock for resistance. Every 914 I've ever purchased had old springs that were no good. Usually unequal height. They are probably on the highest setting because the PO was trying to adjust out the sag. |
| Mike1981 |
Jun 11 2026, 04:52 AM
Hello Everyone.
Thanks for all the advice. Would these be considered quality springs? https://914rubber.com/100-lb-sport-rear-spring-set Or are there other options? Mike |
| stownsen914 |
Jun 11 2026, 05:55 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
I'd agree that the springs are a more likely culprit, but don't discount the possibility of an issue with the shocks. I had some Bilsteins rebuilt once for the front of my 911, and with no other changes it raised the front of the car almost an inch. I was pretty surprised, but apparently the shocks had lost most or all of their gas charge, and rebuilding them increased the effective spring rate.
| Retroracer |
Jun 11 2026, 06:37 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 660 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest
@Mike1981
re: "The drives side is almost 2" lower than the passenger side." If both shocks are on the same setting (high!!) the 2" difference could point to some other possibilities: a) as someone suggested, check the front height L <> R from the arch/floor corner to the ground just behind the front wheels. The height here is easily adjustable via a vertical bolt and these can "back out" over time, leading to mismatch b) the rear arm pivots MAY have worn in their metal location tabs and have loosened or rusted out. This can lead to L <>R height differences and some alarming camber issues, as the arm now "leans" at the wrong angle. If you're taking the coilovers off to adjust you might want to check the integrity of the arm pivots and the "natural resting" angle of the arm which should be somewhat parallel to the ground Here's hoping its something simple like dodgy springs. - Tony |
| StarBear |
Jun 11 2026, 07:06 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,308 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Yep, the 914Rubber 100# springs the way to go. Most other suppliers sell their units.
Lo-Fi Version | Time is now: 11th June 2026 - 07:52 AM |
