> Rattle can expoxy primer experience
sixaddict
post Jun 15 2026, 01:44 PM
I am working on a project and planning to prime a part.
Planning to use rattle can epoxy primer.
Was looking at Eastwood expoxy primer and 2k paint…,( not cheap)
Anyone have specific experience with that or other brand that you could confidently recommend its use.
TIA.
Replies(1 - 7)
post Jun 15 2026, 01:58 PM
SprayMax
Luke M
post Jun 15 2026, 02:20 PM
QUOTE(Superhawk996 @ Jun 15 2026, 12:58 PM) *
SprayMax
I second that. I used their product a few times now and seams to work well. A single can doesn't seam to go far so make sure you get enough. Follow the instructions too. Do not skip a step or you'll be stripping the parts down and redoing it all over again. I was told just that by the guy at the paint store where I purchased mine.
sixaddict
post Jun 15 2026, 02:41 PM
Thanks
bkrantz
post Jun 15 2026, 08:41 PM
I know it's different, but Eastwood two-part clear coat (satin) worked well for me.
post Jun 15 2026, 09:35 PM
QUOTE(bkrantz @ Jun 15 2026, 10:41 PM) *
SprayMax holds a patent on the two part can system for 2k paint.
I could be mistaken here but the Eastwood can looks exactly like a SprayMax can, just has an Eastwood label. (IMG:style_emoticons/default/confused24.gif)
Spray max is about $6-10 cheaper per can depending on where you get SprayMax from and in what quantity. Nothing against Eastwood but I suspect they are basically having SprayMax do a private label for them.
targa72e
post Jun 15 2026, 09:55 PM
A third for SpayMax. You can also get custom colors loaded if needed. Great for smaller touch ups. I can get colors loaded at LKQ Finishmasters locally.
John
sixaddict
post Jun 16 2026, 09:14 AM
More good info
- Lo-Fi Version Time is now: 16th June 2026 - 11:59 AM
