> Clutch conversion question, Pull clutch conversion
DeeEmm
post Jun 15 2026, 09:22 PM
Region Association: Australia and New Zealand
Hi all.
I have a clutch compatibility question.
First here's the parts I have
I have a 914-4 that I purchased without engine and Box. Because...
I already had a 915 box from a 911 SC and a 2.7 Type 4 that has a KEP flywheel with a 911 pull style clutch and ring gear from another project.
My idea was to convert the 915 to work in the 914. But after owning the car for a few years and making no progress, I've changed tact and decided to buy a stock 914 box as one has come up for sale locally. (a rare occurrence here in Australia) Fitting the engine and a stock 914 box is definitely a shorter pathway to getting it back on the road.
So my question is this...
Can I convert the 914 box to work with the pull clutch?
I know that I can change the flywheel to a regular flywheel, but the engine was built and balanced with the KEP clutch and plate, so I would really like to avoid having to tear it down again to get it rebalanced.
I've seen several references implying the box can be converted to a pull style, but I cannot find any hard info on it or anyone who's done it.
The other thought that I had was using a push style pressure plate but still retaining the KEP flywheel and ring gear. But, I'm not even sure if that is possible. Does such a configuration even exist? It would be super convenient if it's just a case of mixing and matching components, but I'm rarely that fortunate.
I do have machining capability as in the sparse info I could find on converting the 914 box to a pull clutch it mentioned machining the release arm pivot? But in the absence of any additional info, I have no idea what that actually entails.
So thought I'd reach out to the brains trust and see if anyone has any ideas / experience on this.
(IMG:http://www.914world.com/bbs2/uploads_offsite/vdubber.com-28216-1781580132.1.jpg)
(IMG:http://www.914world.com/bbs2/uploads_offsite/vdubber.com-28216-1781580133.2.jpg)
Thanks in advance
targa72e
post Jun 15 2026, 10:02 PM
Other can chime in with more details.
Basics I know. The pivot ball is in a different location. Generally recommended to use a insert into the transmission housing and then thread into insert as the Pivot ball can pull out. You need the clutch pressure plate, Clutch fork and throw out bearing from a 2.2 911, all are expensive. Not sure what you use for a clutch cable, might be custom.
john
DeeEmm
post Jun 16 2026, 09:40 AM
Thanks John, that's been a fair bit of help and set me on the right path. I managed to find a bunch of info online based on the info you gave and managed to get an understanding of how it works and the differences between the push / pull setups.
Found an article that explained the difference in pivots and pivot locations and the arms
Found a used release fork on ebay for a very reasonable sum
Ordered a new ball stud pivot
Looking at photos I'm pretty sure the release bearing that I already have is the right one, but will need to wait until I get out in the workshop and have time to dig the engine out to be 100% sure. Looking at photos I think it would be possible to make it work if it wasn't by modifying the arm. Worst case I need to get a new bearing
So I think I'm now mostly set. Of course this will all change when I actually offer the parts up. But that's half the fun, isnt it? lol
Still very interested to hear if anyone has done this mod and if there's any pitfalls I should be aware of
stownsen914
post Jun 16 2026, 09:57 AM
I've done the mod to a 914 trans. If you're lucky to find a 70-71 911 trans, it has the mod. If you're doing it to an earlier 901 or to a 914 trans, you need to have the case machined for an insert for the pivot (magnesium isn't strong enough by itself to resist the pivot bolt pulling out). As mentioned above, the pivot is in a different place, so the shop needs to know where to put it. I happened to have a 70-71 trans case for the shop to copy. Then it's just getting the right parts. For a 911 engine, a standard 72-77 flywheel and clutch bolts up (with a 70-71 911 TO bearing). For a VW motor, I guess you'd need a special flywheel for the crank hub pattern.
1 Members: Cfletch
- Lo-Fi Version Time is now: 16th June 2026 - 11:57 AM
