> Valve Cover gaskets, Glue or grease ?
post Jun 17 2026, 07:28 AM
Should new valve cover gaskets be glued or set in a film of grease ?
post Jun 17 2026, 07:30 AM
I didn't use either Jim. I did weld in some tabs to keep them from slipping though. (IMG:style_emoticons/default/beerchug.gif)
VaccaRabite
post Jun 17 2026, 07:47 AM
En Garde!
A THIN film of RTV on the valve cover side of the gasket only. DO NOT glue the gasket to the head!
This will keep the gasket in place during install and will allow the gasket to be used for years instead of replaced at every oil change.
Zach
post Jun 17 2026, 08:46 AM
Like this ?
FlacaProductions
post Jun 17 2026, 08:52 AM
I use gasketcinch on the cover side and some grease (swepco 101) on the head side.
This keeps the gasket in place and after the bale is snapped in place you can slide the cover around a little and make sure it is seated well.
Also-make sure the VW logo is upside down - or at least put them back on the way they came off.
https://a.co/d/07Kgna1S
rfinegan
post Jun 17 2026, 10:24 AM
both
a little contact spay to hold to gasket to cover and a dab or grease on the side the goes on the head
post Jun 17 2026, 10:57 AM
(IMG:style_emoticons/default/smile.gif) Thanks.
brant
post Jun 17 2026, 11:03 AM
I put them in dry
Usually about 3 uses each gasket
Just changed them and did valves yesterday
Reused the dry gaskets
Test drive this morning and no leaks
post Jun 17 2026, 11:57 AM
QUOTE(brant @ Jun 17 2026, 11:03 AM) *
I put them in dry
you have better luck than me, I use a non drying sealant on both side of the gasket. it's a simple cleanup when next time comes around
1 Members: Jack Standz
- Lo-Fi Version Time is now: 17th June 2026 - 12:39 PM
