> Convert back to D Jet Fuel Injection-, Wire harnessess- Injector Ground
young55961
post Jun 18 2026, 02:34 PM
I have a question about the ECU wiring harness.
There are three pairs of white wires with female spade terminals on the harness. I believe they are the ground wires for the fuel injectors, but I can't find where they are supposed to connect.
Should these wires be connected to the negative (-) terminal of the ignition coil?
If anyone has a photo showing the correct connection, I would really appreciate it. Thank you!
brant
post Jun 18 2026, 02:46 PM
There was supposed to be a three prong connector on the rear engine block through bolt
Back center of engine bay
2 of the three pairs are injector grounds. The third pair is grounds for the ECU and TPS.
They attach to a Tri-spade male terminal located on an engine case through-bolt at the top rear of the engine case, under the air plenum.
young55961
post Jun 18 2026, 02:52 PM
QUOTE(JeffBowlsby @ Jun 18 2026, 03:46 PM) *
Tks.
Let me check.
Ishley
post Jun 18 2026, 08:12 PM
Here is what you’re looking for in the yellow circle.
young55961
post Jun 19 2026, 10:54 AM
QUOTE(Ishley @ Jun 18 2026, 09:12 PM) *
Unfortunately I don't have one there. Most likely get delete during the conversion process.
Thank you anyway.
post Jun 19 2026, 03:44 PM
It's easy enough to get one. Here's one example, but there are others available:
https://www.ebay.com/itm/168409193204
DC_neun_vierzehn
post Jun 19 2026, 03:54 PM
QUOTE(Ishley @ Jun 18 2026, 08:12 PM) *
@Ishley What motor is this?
The location of the tri-spade ground is different on my ‘73 2.0 motor.
@young55961 what is the year and motor on your 914?
Ishley
post Jun 19 2026, 04:25 PM
Mine is a '72 1.7 that I rebuilt into a 2056. The ground spade is stock and in the stock location.
young55961
post Jun 19 2026, 08:17 PM
QUOTE(DC_neun_vierzehn @ Jun 19 2026, 04:54 PM) *
My 75 2.0L
Dave_Darling
post Jun 19 2026, 09:27 PM
914 Idiot
Mine is further back, right by the flywheel end of the motor. But still up on top. Really, any case bolt should work for a ground.
--DD
DC_neun_vierzehn
post Jun 22 2026, 05:27 AM
QUOTE(Dave_Darling @ Jun 19 2026, 09:27 PM) *
--DD
Same.
robkammer
post Jun 23 2026, 05:38 AM
Robbo
Mine is right at the top of the case split at the flywheel. The lower position makes it VERY difficult to get to as it’s under the plenum.
Rob
friethmiller
post Jun 23 2026, 07:33 AM
Observing... learning. I'll be doing this to my LE soon. Jeff B has already tested my ECU but I will be dealing with wiring, the MPS, and other components in a few months probably.
young55961
post Nov 1 2026, 12:22 PM
I'm trying to test-run my 1975 Porsche 914 2.0L D-Jetronic engine outside the car, and I have a few questions about the relay board and wiring harness.
The two pins inside the red square both show 12V with the ignition ON. Is this correct? I also tested the other two pins, but neither appears to be connected to ground.
It seems that the wiring arrangement may be incorrect.
From my understanding:
- **#31** should be ground.
- **#24 and #19** should receive 12V.
- **#18** should receive 12V temporarily while cranking the engine.
Am I understanding these connections correctly? I want to make sure I supply power to the correct terminals before attempting to start the engine outside the car.
Also, I'm not sure whether I should start a new thread for these questions or continue posting in this thread.
Any advice would be greatly appreciated. Thanks!
GregAmy
post Nov 1 2026, 12:31 PM
From my Microsquirt build notes.
T4-I
.75 and .5mm
Into ECU pin 16 (.75) and 24 (.5)
Circuit 87, powered by engagement of the power relay. Medium-size circuit, relayed from large 30.
#24, .75mm (~18AWG) goes to injector drivers.
#16 .5mm (~20AWG) goes to power ECU and sensors.
T4-II
.5mm
Into ECU pin 18, power from T14-1 (track 81) start power to starter solenoid via 12-6; signal to ECU of start circuit
T4-III
.5mm
Into ECU pin 19 86, ground side for fuel pump relay.
T4-IV
.5mm
Power from T14-1 (track 81) start power to starter solenoid via 12-6; CSV engagement
Dave_Darling
post Nov 1 2026, 07:04 PM
914 Idiot
I'm pretty sure that #31 should get grounded by the ECU when it sees that the engine is rotating. It does not get a full-time ground.
--DD
JamesM
post Nov 2 2026, 12:58 AM
Caretaker of 914s - Master of Fuel Injection
QUOTE(Dave_Darling @ Nov 1 2026, 05:04 PM) *
--DD
^That
There are no grounds on the 4 pin. everything with the injection grounds through the tri-spade on the case. #31 activates the pump relay. If you ever want to test your fuel pump/pump relay just jumper that pin to the chassis/ground.
1 Members: sixnotfour
- Lo-Fi Version Time is now: 2nd November 2026 - 05:21 AM
