| gtbarnes |
Jun 21 2026, 07:40 PM
Member ![]() ![]() Group: Members Posts: 50 Joined: 9-July 13 From: nash,tn Member No.: 16,111 Region Association: South East States |
I handpicked the nicest gauges I have and made 1 set of Bullet and 1 of Late type. I believe they are as close to new as can be found. These had almost no sun fade and some of the needles have never been repainted. Only other paint work was refinishing the bezels. They have all been opened and cleaned and all have glass lenses. Anything needing addressing or replacing, was. All odometers have had the gear wheel re-staked to the shaft to not fail. They have all been tested before and after restoration and are working 100%. These Speedometers can vary up to +-5 mph of each other, seems to be the norm. I have also added what I believe to be the best LED lighting system with simple 2 connection wiring and full rotary control of intensity. The LEDs have a dedicated hole/grommet so all factory bulbs can be retained and used and appear totally stock. Your choice. The LED light will match each gauge in intensity no matter where the dial is set and looks factory intentional. Your factory dimmer switch will still control the factory bulbs as stock. These are the nicest 3 gauge sets I have ever seen, they look new in person, pics are hard to show them correctly. They are $599/free ship each. Restored speedometers are $200-$250. Many more pics of these on my web site(some are actually good pics) check them out! |
Lo-Fi Version | Time is now: 22nd June 2026 - 01:33 PM |
