> Way too much gas, 73 1.7 with FI
EJP914
post Jun 24 2026, 09:10 AM
hello!
Looking for some ideas on why the spark plug electrodes are wet with gas after running the car for only about 20-30 seconds. Something is causing way too much fuel into the engine. Car starts at the turn of the key, but stumbles and runs rough. Exhaust smells like gasoline.
I have checked, replaced, or installed known good parts.
New plugs, points, condenser.
Cleaned trigger contacts. Distributer other wise works as it should.
Swapped in known good relay board and relays
Swapped in known good ECU.
Installed new fuel injectors, Standard Mfg type.
Fuel line pressure at 25 lbs.
Swapped in “adjusted” MPS. (Maybe still too rich?)
Timing is good but not spot on.
I have not yet checked CHT sensor or cold start valve (may be stuck open?). Not sure what else to check? I have never seen this much gas get pumped into an engine.
I would very much appreciate any advice and/or guidance. Thanks.
EJP914
FlacaProductions
post Jun 24 2026, 09:13 AM
I'd check the cold start valve.
brant
post Jun 24 2026, 09:43 AM
CHT and mps failure both cause excessive rich conditions
JamesM
QUOTE(EJP914 @ Jun 24 2026, 07:10 AM) *
Those are the three, but im leaning towards the MPS.
For the cold start valve to be stuck open it would first have to open which takes either very cold temps, or a grounded out wire to TS1. Quick test, you could try unplugging the injector but I doubt that is your issue.
CHT failures usually result in a no run condition. Rich to the point of having to floor it to keep it idling.
post Jun 24 2026, 10:08 AM
Check you cht just in case. Easy peasy. Then check your mps. I am betting it doesn't hold vacuum.
post Jun 24 2026, 10:30 AM
I don't know why your car is pumping too much fuel but, I want to point out that you definitely need to change your oil or you can spin a bearing. I did that in a MFI 911 way back when I was 27
Best Bob B
post Jun 24 2026, 02:01 PM
QUOTE(burton73 @ Jun 24 2026, 10:30 AM) *
Best Bob B
Yeah. Check your oil... It may be mostly gas.
wonkipop
post Jun 24 2026, 03:38 PM
another possibility. fuel pressure regulator diaphram failure.
can leak fuel back down the vac line into the air distributor plenum.
- Lo-Fi Version Time is now: 24th June 2026 - 04:32 PM
